Go to Post The other day, I stuck my head into a box of Rhino treads and got a sugar high. - Andy Baker [more]
Unread 13-01-2012, 16:23
sebflippers sebflippers is offline
FRC #2914
sebflippers will become famous soon enoughsebflippers will become famous soon enough
not able to get any programs to work
Hi all,
I have absolutely no idea what is causing this problem, so I just decided to post in this section of the forum. Before the season started, I started doing simple things like getting led's to blink (this is our first year using java). I used image 28 and whatever netbeans plugin version at that time. I got plenty of things working (putting it all in the robotinit() section in the iterative template). Anyway, I have been trying to get some relays and solenoids to work, but nothing worked, so I threw away all of those programs. Just now it occurred to me that nothing has been working since I updated the cRio and Netbeans plugins. The programs still get uploaded. Netbeans says so. But nothing works. Some other things I have noticed: All Digital outputs are at 5v (even though they were not referenced in the code). Also, they solenoids go 1v-0v-1v-0v at 1 second intervals.
Don't worry, I understand the new way of referencing slots, and have updated my code accordingly. Here is an example:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.*;
public class RobotTemplate extends IterativeRobot {
Relay twoWay = new Relay(1,1)
public void robotInit() {
twoWay.set(Relay.Value.kForward);
with the digital module in slot 2. Also, when I reimaged the cRio, I had to format it with labview and the new image, and then go back and change it to java.
any Ideas?
