Go to Post our electronics boards had begun to look like we'd planted a wire bush and it grew - daltore [more]
Unread 13-01-2012, 16:31
BoltAction BoltAction is offline
FRC #1009
BoltAction is an unknown quantity at this point
DLINK Radio Revision
Can please someone tell me what firmware and hardware revisions the dlink dap 1522 is.
Thank You
Unread 17-01-2012, 18:28
FRC #1009
Re: DLINK Radio Revision
Guys pls help....
Unread 17-01-2012, 23:18
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The one we received in our Kit of Parts last year contained firmware revision 1.21, and the two we purchased last summer came with firmware revision 1.40 instead. All three were the original hardware, not the REVB version. I do not know the details of the DAPs in the rookie kit this year.
(We did downgrade the firmware to 1.21 after the newer ones failed to connect to the field at a fall offseason last year. That corrected whatever was preventing them from working properly. I do not know if the FMS has been changed so it is no longer an issue.)
Unread 21-01-2012, 16:35
FRC #1009
Thanx a lot
