Go to Post ...all that matters in my opinion is how much personal growth each one of you all achieve from being a part of this wonderful organization known as the FIRST robotics program. - Elgin Clock [more]
Unread 13-01-2012, 17:47
cesaros cesaros is offline
César Javaroni
FRC #1382 (ETEP Team)
Rookie Year: 2010
cesaros is an unknown quantity at this point
Camera to DashBoard
We are having a lot of troubles to connect m1101 camera to default dashboard.
We have tried to connect the camera to cRIO Port 2 , ran the code AxisCamera &cam = AxisCamera::GetInstance();, and it didn't work.
So we changed camera ip, and connected it to the radio, and it continue not work :/
Does anyone know a solution???
César Luiz Javaroni
ETEP Team 1382
Unread 13-01-2012, 18:03
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Camera to DashBoard
What happens if you open a web browser like Internet Explorer and enter 10.13.82.11 in the address bar? If prompted for a Username and Password use "FRC" for both. It should bring you to a webpage where you can view the camera image.
Unread 13-01-2012, 18:08
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
If you have updated the C-Rio then you connect directly to the radio, meaning that you have to re run the Axis utility and set the ip to: 10.xx.yy.11. Hope this helps
"A team back in training !"
Unread 13-01-2012, 18:24
César Javaroni
Rookie Year: 2010
When I type it opens a webpage, and, we have updated the cRIO, but any of those worked to get images from camera to dashboard, we are using C++.
I tryed now to cam.GetImage();
and yes i have created a FRC/FRC account.
But the dashboard continue not showing camera images :/
César Luiz Javaroni
ETEP Team 1382
Unread 13-01-2012, 18:33
If that webpage and login work, your camera is set up correctly and accessible from your DS computer. That means that something is preventing the Dashboard from getting the image stream. Try turning off any firewall including Windows Firewall and see if that helps.
Unread 13-01-2012, 18:36
César Javaroni
Rookie Year: 2010
We have it turned off.
but, you know if we have to patch any WPILib file, or something like that?
César Luiz Javaroni
ETEP Team 1382
Unread 13-01-2012, 18:41
You have to be using the 2012 Driver's Station, but it shouldn't matter if you've gotten to the language updates or put code on the robot yet (I don't think)
Unread 13-01-2012, 18:47
César Javaroni
Rookie Year: 2010
We are using 2012 driver station, and languages updates, But only making GetInstance(); from program should work ??
César Luiz Javaroni
ETEP Team 1382
Unread 13-01-2012, 18:49
Yes that should work for the robot side, but that shouldn't even be necessary for the Dashboard to show the image in this configuration. I'm not sure why yours isn't working. I'll certainly post here if I think of any other ideas though.
Unread 13-01-2012, 19:03
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
We are having the same very issues! Except with labView. Dashboard isnt seeing it.
Unread 13-01-2012, 19:28
DjMaddius's Avatar
AKA: Matt Smith
The vision assistant does see it though. Dashboard and labview code dont.
