Go to Post Actually, FIRST Is hoping the reverse, that your bot will be "Ball damage proof" - Rombus [more]
Unread 13-01-2012, 17:50
Tub Tubs Tub Tubs is offline
FRC #3049
Tub Tubs is an unknown quantity at this point
Labview release
How can i download the plugins needed for driving the robot, i do not know how to get them
Unread 13-01-2012, 21:25
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
Rookie Year: 2010
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: Labview release
First; you may want to start using the search feature, or even just browse the last 3 days worth of threads. There has been a lot of threads on this. I assume that anything you found wasn't helpful, so you will have to describe what you have done so far.
I would start with this: https://decibel.ni.com/content/docs/DOC-20147
1: Use the USB key provided to install the base packages. (It will appear as a 4GB flash drive, AND a slightly smaller DVD drive. The setup files are in the DVD portion.)
2: Install all of the updates required (All from NI.com)3: I believe there is a cRIO upgrade that is required.
4: Come back and ask again when you get stuck.
Good luck.
Mike B
Unread 14-01-2012, 21:25
FRC #3049
Re: Labview release
Thanks it works and i am on my way to finishing.
