Bridge question
The practice field ramp does not pass the battery calibration test with the dimensions given. Should the hinges be further apart?$@#
Re: Bridge question
I would leave the hinges where they are so that the bridge tips at the correct angles.
You may want to consider adding weight to the middle of the bridge (near the hinges) or the edges, depending on which way it is incorrectly calibrated. |
Re: Bridge question
He's not saying that the bridge tips to one side, just that it requires less force than the real field should to tip in either direction. I would recommend adding weight to both sides or using a spring or other stretchy device.
Re: Bridge question
How off caliber is your bridge? We constructed a low cost one ourselves and we were only able to move batteries 14" off center before tipping.
Re: Bridge question
We are having the same problem, but we follewed the drawings very closely. I don't understand how this could work.
Re: Bridge question
the surfaces are also not spot on friction wise... |
Re: Bridge question
If you can only move the battery 14", then you need a heavier bridge, which means add 2 equal weights an even distance from the center. If you were so inclined, you could measure the actual distance from fulcrum to center, then do the math and figure out exactly how much weight to add. If you want the dynamics as close to competition as possible, then pay attention to all measurements dealing with the hinges: their distance from the floor (and therefore also their distance from the deck), and their gap. Last edited by lcoreyl : 14-01-2012 at 17:01. Reason: added last paragraph |
Re: Bridge question
We are also haveing the same problem. On one side the batteries will go about 16 in and on the other side only 13 in before tipping. We tried adding weight to the center to see how much would be needed. It took 140 lbs to make the bridge balance with the batteries 28 in from the center. Has anyone come up with a solution that doesn't involve putting that much weight on the bridge.
Re: Bridge question
We made a cheap version using wood, and we had the same problem. however we fixed it by adding 40 pounds to each side.
#10
Re: Bridge question
It took 60 lbs on each side to keep the batteries at 28 inches on the better side (the one that will go to 16 in before tipping). With 60 lbs on each side it makes transporting it a real problem so it is not very practical to use this as a final solution. Has anyone come up with a way to use surgical tubing or something like it to fix these problems?
#11
Re: Bridge question
Just make the 60lbs on each side removable and transport as before.
#12
Re: Bridge question
Adding weight will not make the bridge behave differently.
You need to add a variable force, such as a spring or bungee cord, between the bottom of the bridge and the baseplate, and calibrate that until you get the right motion. Do this on both sides, of course! |
#13
Re: Bridge question
Re: Bridge question
Same problem.
I also noticed that our bridge is a bit flimsy. Lots of torsion when two people walk over it. I'll be adding some 2x4 blocks between the 3/4" trapezoidal supports, and from these I'll try hanging weights. I wish I had saved last year's dead batteries! And Joe Johnson, thank you for the explanation. My first instinct (as a physics teacher) was to claim that it should not matter how massive the bridge was. After checking the actual game pieces, and seeing the hinge points were at the same positions, I was trying to figure out how increasing the mass will matter. The fact that the hinge points are off-center does indeed mean that the CG will be lifted when the bridge tips up. I'm only upset that I didn't see it myself |
