Go to Post How you say something is often just as important as what you say. - Rachel Lim [more]
Unread 14-01-2012, 11:37
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
Chassis Front End Design
Camer up with this last night. It's hard to read, but the angle measurement at the bottom of the slope reads "30 - 45 degrees" and is just a rough estimation.
Comments?
Name:	Photo on 2012-01-14 at 11.33.jpg
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 14-01-2012, 21:12
HammadB's Avatar
HammadB HammadB is offline
FRC #0295 (Renevatio)
Rookie Year: 2007
HammadB will become famous soon enough
Re: Chassis Front End Design
We prototyped something similar with the kitbot with the plate made out of lexan, the plate sat a little higher than yours in relation to the wheel and had a 30 degree angle, it worked at very slow speeds successfully and calmly, only thing is you will need to do 8 wheel drive (to make it easy)
Unread 14-01-2012, 21:13
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
Team Role: Mechanical
the man is on a distinguished road
What about a nylon block / strip?
Every day is a new adventure!!!
Unread 14-01-2012, 22:51
J.Warsoff's Avatar
BECAUSE SCIENCE
AKA: Jared Warsoff
Did you have a wide or long chassis? We were testing it on a test wide chassis, and it was not pretty. The thing jumped straight up 3-4 inches off the ground. Once we get a test long chassis going, we will see what we need for wheels and drive. We had a similar system for our 2010 bot, without the lexan though. That was only 6 wheels, but did really will. We'll just have to see
Also, the drawing is not completely accurate. We actually have the entire wheel set a little farther back, so it is behind the lexan plate.
Unread 15-01-2012, 03:07
HammadB's Avatar
Rookie Year: 2007
We tested a narrow base, this obviously helps, I'll try to get a video on Monday (our team doesn't meet Sundays)
EDIT: Also, our skid plate was curved rather than a straight angle, and was long enough so that it pulled the 6 inch wheel's center right at or little above the bump, thats the key
