Go to Post I've never seen a spam bot edit posts before - Vikesrock [more]
Unread 14-01-2012, 11:46
1997dodo 1997dodo is offline
FRC #0449
1997dodo is an unknown quantity at this point
Kinect WPI library error 7
Hi all, I was wondering if anyone else has gotten an error when trying to use the Get Kinect Extra VI provided with the new labview. The error traces back to the getDynamicControlData function, which has no path specified under "Library name or path". Does anyone know how to fix this?
Many Thanks.
Unread 14-01-2012, 11:54
Re: Kinect WPI library error 7
I have not tested it in a few weeks, and I unfortunately didn't bring my Kinect home. If the error is truly claiming you don't have an FRC_NetworkCommunications.out file, then very little will work on that cRIO. Do the other Kinect VIs work?
Greg McKaskle
Unread 14-01-2012, 11:56
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Many Thanks.
Are you trying to run this code on the cRIO or targeted to the computer? Those VIs appear to be meant for the cRIO.
Unread 14-01-2012, 12:01
FRC #0449
we're attempting to run the VIs on a computer because we don't want to set up the cRIOs right now. Our team leader says it will take too long.
Unread 14-01-2012, 12:04
That won't work. The vast majority of the WPILib VIs will not run targeted to the computer without some (and for many heavy) modification. You're going to need to set up your cRIO if you want to test out the WPILib VIs.
Unread 14-01-2012, 12:10
FRC #0449
I'm willing to go through heavy modification... problem is, I'm not experienced enough to know how. The rest of the team is busy prototyping to stop and set up a cRIO for us to play with. so, i guess we're screwed...
