Go to Post If no hint or advanced BOM don't come out, will it make you not participate in FIRST this year?? - Elgin Clock [more]
Unread 14-01-2012, 16:40
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Sensing RPM with the kit encoder.
Can the CRio keep up with the counts from the kit encoder if it's on a shaft rotating at 2500-3000 rpm? I'd like to run a velocity PID on our shooter. IIRC, the kit encoder doesn't have an indicator pulse, meaning you'd have to count all of the pulses. However, I don't know how many PPR the kit encoder has.
Unread 14-01-2012, 17:10
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: Sensing RPM with the kit encoder.
Code:
private double[] getRPM()
        double rpm[] = new double[2];                                               //Declares an array of integers which the function will return.
        currentTime = time.get();                                                   //Sets currentTime to the time calculatged from FPGA
        rpm[0] = leftEncoder.getRaw() * 16666666.666666 / currentTime;              //dAngle*(60000000us/360deg)/dTime = RPM
        rpm[1] = rightEncoder.getRaw() * 16666666.666666 / currentTime;             //dAngle*(60000000us/360deg)/dTime = RPM
        leftEncoder.reset();                                                        //Resets the left wheel encoder.
        rightEncoder.reset();                                                       //Resets the right wheel encoder.
        time.reset();                                                               //This resets the timer.
        return rpm;
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 14-01-2012, 17:25
Robotics Engineer
Thanks for the code. Im just asking if the FPGA can keep up with the speed that the counts will come in from a 3000 rpm shaft.
Unread 14-01-2012, 17:58
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
https://decibel.ni.com/content/message/12523#12523
Unread 14-01-2012, 18:10
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The US Digital KOP encoders are 360 CPR.
They are rated at 10,000 max RPM
At 1X the cRIO will keep up.
