Go to Post "Oblivious" people asking questions are what gives us an excuse to sit around on CD. - Ryan M. [more]
Unread 14-01-2012, 17:12
Joel Braun Joel Braun is offline
FRC #1388
Rookie Year: 2011
Joel Braun is an unknown quantity at this point
Using Allen-Bradley light sensors as beam detectors
Hi all,
Our team (1388) needs a way of counting basketballs into and out of our feeder system similar to how beam detectors work, such as the devices that make sounds when you walk into or out of a building.
After some brief searching over Andymark and the general internet, we've been unable to find anything that would be usable in this purpose. With that in mind, the idea of using Allen Bradley 42ef-d1mnak-a2 light sensors came into play. Could we use these to count basketballs as they entered our robot, or is that too far outside of their intended design? If it is, what sensors would be recommended for this purpose?
Unread 14-01-2012, 18:57
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Using Allen-Bradley light sensors as beam detectors
Originally Posted by Joel Braun View Post
Hi all,
Sometimes, you can use a "beam sensor" with a reflector. Try to mount a beam sensor, and place a reflector on the otherside for it too look at. Generally this will create an ON SIGNAL. When your ball passes through the beam sensor, it will turn off. You might have to adjust your gain to a lower setting.
Of course the right sensor to use would be a through beam sensor. Like this for example:
http://www.automationdirect.com/adc/...X-z-FE_Series)
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 14-01-2012, 19:05
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
yes, you can use those sensors and a retroreflector... if you play with the tuning knob you can use them as a beam break... maybe not what they were designed for, but heck, retroreflectors are easy to find and if you have a few left over from last year, you are some wire spices away from a prototype.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
