Go to Post We can either sit around and complain about what could have been, or we can focus on the upside of what we have and move on. - Vikesrock [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 14-01-2012, 17:47
nazgul42 nazgul42 is offline
FTC #4115
nazgul42 is an unknown quantity at this point
Tetrix Encoders not returning consistent values
On the robot that my team built, there are two motors with encoders on them. The software running on the NXT brick is written in robotC. It looks like:
Code:
// Motor definitions here
task main()
  nMotorEncoder[leftArm] = 0;
  nMotorEncoder[rightArm] = 0;
  while (true)
    nxtDisplayTextLine(1,"RArm: %d", nMotorEncoder[rightArm]);
    nxtDisplayTextLine(3,"LArm: %d", nMotorEncoder[leftArm]);
If I rotate one of the motors about 90 degrees, the displayed encoder value changes to about -200. If I then rotate the motor back to the position where it was at zero, the encoder value changes to about 250. Since the encoder changes faster in one direction than another, there is no actual 'zero position'. The other encoder displays this same behavior. Why does this happen?
Unread 14-01-2012, 20:01
Rainydaymaker's Avatar
Rainydaymaker Rainydaymaker is offline
AKA: Jim
FRC #1983 (Skunk Works)
Rainydaymaker is on a distinguished road
Re: Tetrix Encoders not returning consistent values
This can be due to a scratched encoder rotor. Or a nicked encoder wire.
Unread 14-01-2012, 23:37
FTC #4115
If the scratched encoder rotor is the case, is there any way to fix that?
