Go to Post "You know, a robotics regional is the only place where you can walk in and see two people in chicken suits and not be confused." - Herodotus [more]
Unread 01-14-2012, 09:10 PM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
SimpleTemplate project not working
We can build, deploy and run the BuiltinDefault project and it works as expected. The SimpleTemplate project does not run the motors. We printed out the joystick inputs and they look correct. Anyone else have the same issue?
Unread 01-14-2012, 10:45 PM
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Are the motor ports correctly set to match your robot?
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 01-14-2012, 10:55 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Re: SimpleTemplate project not working
Brad
Left and right are connected to PWM 1 & 2 - the BuitinDefault example project works w/o touching the hardware.
Unread 01-15-2012, 11:25 AM
pmalmsten pmalmsten is offline
pmalmsten is on a distinguished road
Would you mind posting the SimpleTemplate-based code which does not work?
Unread 01-15-2012, 11:32 AM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
I'll post the code when I get back to our lab. But it is the SimpleTemplate example with NO alterations.
I know this sounds weird. We must be missing something simple. I did not beleive the students when they first asked for my help. But I'm an expert with Workbench and VxWorks and I can't see why it should not work. The BuiltinDefaultCode project works but the SimpleTemplate does not. We can load one right after the other and reproduce this every time so we KNOW there are no hardware configuration issues.
Could it be the safety functions? That is the only real difference in the 2 examples.
Thanks
Unread 01-15-2012, 12:42 PM
The SimpleRobotTemplateProject does not include any code to read sensors, drive wheels, etc. It's only a template for a project, not an example. It will do nothing.
To make this do something, you will need to create your own motor objects and joystick objects. There's a method called operatorControl() in the code included within the SimpleRobotTemplateProject; this will be called when the robot enters teleoperated mode. Put your code there.
Take a look inside the sample projects or look at the documentation for WPILib to see how this works.
~Paul Malmsten
Unread 01-15-2012, 12:50 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Paul,
The C++ simple Template code does indeed contain code for doing arcade drive of a two motor robot.
Keith,
Are you seeing any errors in the Messages box on the Driver Station Diagnostics tab?
Unread 01-15-2012, 12:57 PM
My apologies, I mostly work with the Java branch of WPILib, and nothing is included in the equivalent SimpleRobotTemplateProject in that world. Ignore my previous post.
Have you tried using the NetConsole to look for errors? You can enable this from the FRC cRIO Imaging Tool, and then run the NetConsole on your laptop. In some cases error messages will appear there.
~Paul Malmsten
Unread 01-15-2012, 05:24 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Thanks for the input guys. There are no messages coming from the console after the code starts up (but I have not run it from the debugger yet) . I am thinking it has something to do with the safety functions but have not gotten back to the lab to try anything new.
We do not use SimpleTemplate for anything on the competition robot. Our "real" code is built directly on the RobotBase classes and uses multi-tasking and a message system (using VxWorks msqQLib) to implement all the competition features. Our rookies built the kitbot at a QuickBuild session and were trying to practice some programming skills.
Unread 01-15-2012, 08:22 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
This the code for the simple robot template project.
#include "WPILib.h"
* This is a demo program showing the use of the RobotBase class.
* The SimpleRobot class is the base of a robot application that will automatically call your
* Autonomous and OperatorControl methods at the right time as controlled by the switches on
* the driver station or the field controls.
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick stick; // only joystick
public:
RobotDemo(void):
myRobot(1, 2), // these must be initialized in the same order
stick(1) // as they are declared above.
myRobot.SetExpiration(0.1);
* Drive left & right motors for 2 seconds then stop
void Autonomous(void)
myRobot.SetSafetyEnabled(false);
myRobot.Drive(0.5, 0.0); // drive forwards half speed
Wait(2.0); // for 2 seconds
myRobot.Drive(0.0, 0.0); // stop robot
* Runs the motors with arcade steering.
void OperatorControl(void)
myRobot.SetSafetyEnabled(true);
while (IsOperatorControl())
myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
Wait(0.005); // wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
Unread 01-16-2012, 02:20 AM
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
Rookie Year: 2010
enrique will become famous soon enough
Send a message via Yahoo to enrique
Smile Re: SimpleTemplate project not working
A couple of things to check:
In the code, make sure your speed controller declarations match the speed controllers your using. (Victor, Jaguar)
Make sure the digital side car shows 3 green lights in the area that shows 5v.
If it does not then your missing the digital side car power.
Make sure the side car cable is tight on both sides.
Make sure the modules are in the correct slot.
If you tried the above then try a new side car.
If still having problems then try changing the actual module.
