Go to Post Looks like it will be to your advantage to keep the Refs happy. Remember, Donuts go a long way toward that end! - billbo911 [more]
Unread 15-01-2012, 00:17
pavie pavie is offline
AKA: Paul Bieganski
FRC #3630 (Stampede)
Rookie Year: 2011
pavie is an unknown quantity at this point
Missing C:\windriver\WPILib - no vxWorks cRIO images
Hello! We are trying to get the vxWorks environment set up (we're coding in C++). We have re-installed all (?) components three times (NI FRC tools, WR DVD 1 & 2, FRC2012Utilities.zip) and we are trying to re-image the cRIO, but there is no WPILib folder in c:
\windriver (so the cRIO imaging tool cannot find any images). Is there some "WPILib installation" step that we are missing (nothing is mentioned in any documentation)?
Thanks!
Unread 15-01-2012, 00:27
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Re: Missing C:\windriver\WPILib - no vxWorks cRIO images
Did you install the WPILib C++ update from here? It was documented in the Getting Started with the 2012 Control System document.
Unread 15-01-2012, 09:15
AKA: Paul Bieganski
Rookie Year: 2011
Smile Re: Missing C:\windriver\WPILib - no vxWorks cRIO images
We managed to miss it - thank you!
