Go to Post GP may not be as common as we would like out in the "real world" but Ladies and Gentlemen it is out there. - Jay H 237 [more]
Unread 15-01-2012, 01:47
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
Rookie Year: 2011
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
wheel question
I was wondering - what will happen if we build a robot that has wheels in different size? For example, let's say we build the frame from the kit with 8'' wheels in the middle and 6'' wheels on the sides. What will happen?
I know we'll have to adjust the gear so that they'll spin at the same speed, but then the torqe will be different. Will it be substantial? How stable will the system be?
Thanks in advance.
2212!
Unread 15-01-2012, 02:00
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Re: wheel question
I dont think that the different speeds/tourqes of the wheels will greatly affect it, but if the robot has a center of gravity near the center then it will tip from one way to the other depending on what way you are driving. That may be able to help you with the bump though.
Unread 15-01-2012, 02:11
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: wheel question
Well I'm assuming he'd have all 3 wheels on the same level, as in the axles would be at different heights off the ground for the 6" and 8" wheels, so that all wheels touch the ground.
I don't think you'd have a torque difference, man. Think about it, in order to have the wheels spin at the same relative speed in terms of ground distance, you'll need to increase the rotational speed of the 6" wheels. Thus, if you increase the speed, you'll decrease the torque. So the 8" wheel axle will have more torque than the 6" wheel axle, but when you then consider the 8" wheel will cover ~25" of ground distance per rotation as opposed to the 6" wheels which cover ~18.8," the wheels will end up having the same relative torque because they'll have the same relative speed. Using the same drive source, if you increase power, the inverse happens to torque, and vice versa, so all in all it comes out being equal.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 15-01-2012, 04:50
David Guzman's Avatar
David Guzman David Guzman is online now
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Re: wheel question
If you adjust the speed to match on both size wheels, you will also be adjusting the torque at the same time. A reduction in speed increases torque and because your wheel size is different (different moment arm) the force applied to the ground ends up being the same.
As long as you adjust the RPM to match the correct robot moving velocity, you will be fine.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
