Go to Post Paul Copioli - A guy who is 13 years older than me, but acts about 13 years younger. - Amanda Morrison [more]
Unread 15-01-2012, 08:13
Bgrill Bgrill is offline
FRC #2537
Bgrill is an unknown quantity at this point
Question Question on how to attach Pneumatic tubing
Hey everybody. My team is trying to attach pneumatic tubing to itself to use in moving the balls. We have tried several methods unsuccessfully. Are there any ideas on how we could do this?
Unread 15-01-2012, 09:58
speedbuggy76 speedbuggy76 is offline
Manellis
AKA: Matt Ellis
FRC #0118 (The Robonauts)
speedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the rough
Re: Question on how to attach Pneumatic tubing
I guess you mean you're trying to form belts from it? I don't think I've ever tried that, but have you tried heating it up already? That would be my first bet, but I could see it losing its shape since it's so hollow. You should check out polycord as a belt material. It has a similar diameter and is pretty easy to melt together.
Mentor for Team 118 - The Robonauts
Former mentor of 2415 - The WiredCats
Former member of 1002 - The CircuitRunners
Unread 15-01-2012, 10:01
FRC #2537
Smile Re: Question on how to attach Pneumatic tubing
I am trying to make belts. i have tried heating it and it lost its shape and became weak. polycord is an interesting idea though.
Unread 15-01-2012, 10:06
IrksomeZeus IrksomeZeus is offline
Electrical Team Leader
AKA: Austin Yates
FRC #3003 (Tan(x))
Team Role: Electrical
Rookie Year: 2010
IrksomeZeus is an unknown quantity at this point
you might be able to use just the quick connect couplings if you just wanted a loop...
Unread 15-01-2012, 10:11
Manellis
AKA: Matt Ellis
Those won't go around pulleys very well though, at least the ones of the size we expect to use. You could try using something to plug them together in the inside part of the tube, but even that might start to come undone after going around a couple times.
Unread 15-01-2012, 10:13
FRC #2537
We tried cutting the threaded part of of bolts and twisting them into the tubing. after a few turns around the pulleys they slip out.
Unread 15-01-2012, 10:15
470-RBTX's Avatar
470-RBTX 470-RBTX is offline
Team Schmooze Captain
FRC #0470 (Alpha Omega Robotics)
470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of
We use poly chord or drive chord for almost everything except the drive train, it's nice because you don't have to deal with chain-breakers, chains, sprockets and grease.
I am here: http://maps.google.com/maps?ll=42.215248,-83.620053
Unread 15-01-2012, 10:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I wonder if this link will work?
http://www.mcmaster.com/#urethane-round-belts/=ftfbhi
We are ordering some of this stuff to try out, other teams have used it successfully for years.
Unread 15-01-2012, 11:33
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
yeah, it's good stuff alright.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 15-01-2012, 11:43
krazyman1013's Avatar
krazyman1013 krazyman1013 is offline
FRC #0701 (RoboVikes)
Team Role: Leadership
krazyman1013 is an unknown quantity at this point
Don't use any pneumatic tubing for belts, poly-cord works much better and it is easy to bond to itself.
