Go to Post Learn to respect the opinions of others, even if they are the complete opposite of yours. - Hallry [more]
Unread 17-01-2012, 13:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Window Motors and Rotation
To make the motor turn in precise increments, requires feedback and motor control. Use an encoder (a potentiometer will probably work and only costs $3 at Radio Shack) and a Victor or Jaguar instead of a Spike to drive it. Then you'll get to discover the joys of a PID loop, and getting the constants right.
The potentiometer is mounted so it moves as the motor moves, and connected to an analog input.
Unread 17-01-2012, 14:43
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Originally Posted by Roboticsismylif View Post
You should have gotten 4 window motors, two right and two left. They have moderate speed and lots of torque. As for coding they use a "spike" relay. The coding should be the same for them as any other spike. With the spike you can reverse the flow of energy making the window motor turn the opposite dirrection.
There were only 2 window motors, weren't there?
Unread 18-01-2012, 21:22
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Two motors in the KOP, up to two additional available through the ARA program.
Al
WB9UVJ
www.wildstang.org
________________________
