Go to Post srawls: Look, all I did was say "Hi, my name is John V-Neun" and it just happened... - dlavery [more]
Unread 15-01-2012, 17:33
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Driver Station - HD filling up from Camera capture images
The DS seems to automatically save images of the camera once a second.
We are using the Classmate '09, and HD space is at an extreme premium.
Our HD fills up pretty quickly due to this feature, and I'm wondering if we can disable it?
I can't seem to find the option to do so, and have been manually deleting all the log periodically.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 15-01-2012, 17:49
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Driver Station - HD filling up from Camera capture images
It should be saving a maximum of 60.
Build a default Dashboard project and disable (or add a control to disable if you want) the "Save DB Images" in Dashboard Main.vi
Unread 15-01-2012, 18:31
As mentioned, it should only keep the last sixty, and they are usually tens of kB each. There is a single subVI inside the vision loop that does the logging. Delete or disable it.
There is another logging feature that is in the DS rather than the DB. The DS logs the battery, packet loss, cpu usage and a few other values every 20ms. The log files are stored in the Users/public/Documents/FRC/Log Files. The files tend to stay pretty small, but there is no automatic limiter to how many files are kept. Over the last six weeks, I've accumulated less than 200MB. It is possible to turn off the logging for a session, but unlike most of the DS settings, the setting doesn't stick, and defaults to on each time the DS is restarted. This was primarily for troubleshooting at events, but should be useful for general usage. Please keep an eye on it, remove the files as needed, and if necessary, a newer version can limit or have a disable switch added.
Greg McKaskle
Unread 15-01-2012, 18:51
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
in the past I just wired the get image vi. to the display image .vi, skipping/deleting the save .vi.
in addition to saving a hair of hdd space, it made the frame rate a lot better and made adding crosshairs to the display without flickering possible.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 15-01-2012, 18:53
Are you sure that this impacted your framerate? I'd love to hear details.
Greg McKaskle
Unread 15-01-2012, 19:04
ratdude747's Avatar
AKA: Larry Bolan
Greg McKaskle
well, it was a marginal improvement. the big thing was de-flickering the crosshairs.
Unread 15-01-2012, 19:24
The flicker is annoying. Usually, the solution is to right click on the display and turn on Snapshot.
Greg McKaskle
Unread 15-01-2012, 19:40
Just Itinerant
The special viewer for those DS log files is located at:
C://Program Files (x86)/FRC Driver Station/Driver Station Log File Viewer
