Re: 3 robots designs I hope to see this season
Really, if you so wholeheartedly believe you will get away with blinding the opponents with a 84" blanket, go ahead. Just don't come crying to CD when you don't get to compete.
Then you throw in [G07]... |
I believe after your first regional, you'll appreciate what BJC and artdutra are saying a little bit more. No offense, but they have a combined 14 years of FIRST experience. If you think 20ft is hard with a poof ball, you should of seen the teams doing it with a 12lb track ball in 2008.... Last edited by Thermal : 16-01-2012 at 00:39. |
And what makes 30fps hard to reach? Your robot already travels at 12-15 and it weighs 135lb...
So this is basically a direct drive with 2 CIM motors, the chunkiest of the chunky, and at the maximum distance angle (45 degrees) he is hitting 23 feet. That's far enough to also cause more problems. (note the editing might not have been for just collecting the ball). And it doesn't seem to include the ball after ball wheel slow down either. |
), and now have balls shooting out about 58-60 feet. No gearing, 100% legal. |
I wanna one-up the half court shooter. I wanna see a robot that can line up in front of the feeder station and pitch-machine top hoop goals consistently. I'm not well-versed on motor math, so I have no idea how feasible this is, but its something I'd like to see.
#10
I would go for the consistency and simplicity and reliability and easy repairs that one arm offers whether it be any type. |
#13
You can use a different power motors in the same mechanism easily without any problems, as long as you match the free speed to within a few percent of each other. For example, if Motor A is 10,000 rpm and motor B is 5,000 rpm and you want to use them in the same gearbox, simply gear down Motor A 2:1 before you interface it with Motor B.
#14
If you mix two motors in a given system, and gear them appropriately, they will share the load. Why? Say I have a CIM (free speed say 5000rpm for this simplified example, with a torque of 1 units) and a FP (free speed say 20000rpm for this simplified example, with a torque of 0.2 units) I gear the FP down 4:1 before mixing it with the CIM. The free speeds now match, but the FP only has an equiv. torque of 0.8 - the sum of the stall torques of the two motors geared together is now 1.8 units When I apply a load to this system, the motors will slow down because there is a load. Say I apply a torque of 0.9 - half of our stall 1.8. Assuming everything is perfectly linear, the motors will slow down to half speed. Because they are geared together, they HAVE TO RUN AT THE SAME (relative) SPEED. Since, at a given speed, each contributes a different amount of power, the power they contribute is approximately correct, the sum of their power output is equal to the load, and given the power output of the motors, the larger motors will contribute more power than the smaller motors. - In this example, the CIM would contribute 0.5 torque units and the FP would contribute 0.4 after gearing (the FP sees 0.1). You can effectively gear motors relative to one another and add their (geared) torques without much issue, and design the system as if it was a single super motor. To make things even better, most of the motors in the KOP come in pairs, and you can have up to 4 CIM or BB's, so you don't often need to mix motors of different types. (as a side note, BJC and I wrote up some TI-84 equations/graphs for throwing a ball, and it wasn't as bad as you make it sound, balancing the ramp isn't very hard for a single human-driven robot, and if you are ever in the opposing alley it's a penalty under [G28], even if you were collecting balls) |
