3 robots designs I hope to see this season
I am not affiliated with a team, so I have little to no influence on any of the designs of this years game. However, I will be watching competition and here are the robots I would love to see.
1) Simbiotics 2008 look alike What I envisioned before Friday: http://www.simbotics.org/media/videos/2008 What I envisioned after Friday: http://www.youtube.com/watch?v=C2UA7...layer_embedded I think having the entire front of a robot pulling in and funneling the balls to a central arm that can only hold 3 balls(per rules), elevate them to a height, and spit them back out would be a great and quick way to score balls that your alliance has either missed or are just loose. Of course, the poofs bot is a little tall, but I have confidence that teams will be able to engineer a way to solve this issue. This robot will be a game change because it is a relatively easy design that has the potential to score efficiently and quickly. Many high performing teams will have a similar designs and they will love to be alliances with team that can feed them balls. These teams will win matches in qualifications if they can keep control of the balls, and will be considered great robots in eliminations. 2) Half Court Shooter What I see is a robot that can sit in the alley against it's own bridge(for alignment purposes) and can shoot either high balls or balls with lots of backspin across the court. The purpose of that is to either have a larger target to hit, or to give the ball a push downward when it hits the backboard. Not only that, but I would love this robot to essentially be a giant net, with the back of the robot being very low to the ground. This would allow the human player to easily bounce pass the ball into the robot, or to toss the ball half court into the robot. Bonus points if the team calibrates the robot to be able to score while on the bridge in the final seconds. Teams using this design will not rank very high, not because they will not score well; this design means that this particular robot can only score balls that their opponent scored first. There will not be many teams like this(think 469 in 2010) but will be first round picks for eliminations. Think: what if your alliance had a robot that could score all the balls your opponent does after they score them? If you can do that, then you can not fall behind during teleoperated period. This robot will be a game changer. What gets me excited about this design is if both alliances have a robot capable of doing this well, then the scoring will be high and it will all come down to the bridges and hybrid. 3) Bridge Bots Teams planning on using designs 1 and 2 will probably consider the bridge and attempt to balance, but will be either mediocre balancers or to large/odd weight distribution/not enough experience to balance on the bridge. Not that some teams won't excel at scoring and balancing, but these robots will be able to balance with almost anyone and will be experts at it. This robot will be small, think of 148 in 2008, but will weigh the max amount. This robot will be able to get onto and locate the center of the bridge. The robot then will be able to tilt the bridge either way without driving in either direction. They will do this with a light frame and heavy weights inside the frame that allow them to shift the center of mass to either side. If teams ever balance 3 robots, it will be because a robot similar to this was on the alliance. Not to many teams will have this design because you will not be a scoring bot, but these teams will get a lot of attention from other teams. What will be interesting about this design: Although their capabilities will be quite limited, they may be able to be one of the highest ranked robots at any regional. This is because of the qualification points you get while balancing with the opposing alliance. Winning is fine and dandy, but what alliance would not tell their team mates that had this capability to assist the alliance in elevating to assure you get the qualification points; likewise, what opposing alliance would not agree! This robot will get attention early, and they will be the team everyone remembers from this year. Feel free to comment on with your own designs you hope to see this year. |
Re: 3 robots designs I hope to see this season
Very interesting, however, based on the popular designs of a pitching machine bot, half court take a muzzle velocity of 34 ft/sec and full court back corner shot take 50 ft/sec, which is too far for a spitting robot. Only a direct contact bot (throwing) will be able to put enough mechanical efficiency into the kinetic motion of the ball. Also, the goal being so far away, only math will be able to make the shot, not human controls, so this competition is 99% robot.
On the three shot robot, there is absolutely no way to load 3 balls at a time, and shoot all three with a spitting bot or any bot for that matter. The balls simply are too heavy. Also, the bridge bot would take a lot of weight in pieces alone to get the balancing right (i.e. wormgear secondary drive to lock position.). Also, balancing isn't inside it's own special timeframe like the autonomous period is. That means one team will have to sacrifice probably 30 seconds (1/4 the game) to just attempt to balance by themselves. That being said, a competent robot that can score will have more at least 10 points without having to worry about the probably of not balancing. Also, it wont be sabotaged in balancing. If I were the other team and saw someone balancing, i would simply take a 3 point foul and touch the bridge to make it "not supporting all robots) instead of have a team score 10-20 points off a chassis bot basically. |
And finally, [G25] Robots may not contact or otherwise interfere with the opposing Alliance Bridge. Violation: Technical-Foul. If the act of Balancing is interfered with, also a Red Card and the Bridge will be counted as Balanced. You need to get your facts straight or you're going to be very suprised come competition season. Regards, Bryan |
And actually holding three balls then shooting them is almost 2.5 pounds to shoot. There is no way to shoot that much weight at one time from 10 plus feet. that is too much torque that when geared down, is too low an RPM even with the CIM motors. Our design holds 2 yet the bot will only weigh around 50 pounds and is an active collector and shooter from literally all spots on the field. A collector in this game may not be worth it since it would be difficult to drive a ball into the narrow side of the bot that has a maximum of 11 inch opening and the wide side (22 inches) where any corners could damage the ball by running over it. (and the ball is also 8 inches in diameter which means a claw in that area would have to be very slender) Also, the driver will be 30+ feet away to gather the balls if it hasn't any in the bot itself which could be facing away from it. The driver is threading a needle. |
![]() 1. Build a bridge and try to balance a robot on it, it's not that hard. You really don't need anything special. 2. Those 15 holes are less than 1/4 inch deep. They only go through the polycarb covering on the bridge. 3. You will have a difficult time trying to block a robot that is balancing from it's ally. 4. You are presumably not shooting all of your balls at the exact same time (you would have a difficult time making them all go into the basket.) 5. You do not need a CIM geared down for torque to shoot 8" foam balls. 6. You should not expect to be able to score into a basket from anywhere on the field consistantly. 7. Collecting off the ground in this game is extremely worth it. It's called Rebound Rumble for a reason. 8. Drivers have been "threading needles" for years in FRC. You have to get good at it or expect to loose to someone else who can. Good Luck in your first FIRST season, and try to stay open to new ideas and alternative perspectives. Bryan |
![]() And we did until we weighed pros and cons with prototyping and mathematical analysis. Balancing will be a huge challenge considering its worth a lot of points (relatively) and the boards are pretty small for 3 bots. Also, collecting off the ground doesn't necessarily mean something that runs along the ground. Gripping on the holes is considered grappling as well if suction cups are, so I would avoid even touching them. Draw a spreadsheet to find the needed acceleration and muzzle velocity for even 20 feet away. It's some rather big numbers for that 11.2 oz ball. You can block an alley easy if you just rolled over there in the last half minute "collecting basketballs". And when threading the needle, I would rather have my robot thread a needle than a driver. Like a sewing machine versus a hand sewer. Though the hand stitching may look prettier, the sewing machine proves a better more precise, versatile, dependable stitch. |
I'm not saying you're a bad guy/girl, however this is just a heads up. Double, if not triple check what you're about to say before you say it. Sometimes it can stop you from saying things you would have really regretted. Thanks for listening, and good luck this season! ![]() |
#10
I'd love to see a robot that basically blocks the view of drivers. Since you can extend to 84 inches up and 14 inches out on the side of the field where you score, that is right in front of the opposing alliance's drive team right? Well I'm wondering if a team will abuse this fact and have a giant blanket to completely obstruct a drive team's view of the entire field. What a predicament that would be!
The drive team would need to rely on instructions from the Inbounders or other teams as to how to navigate their robot. This sort of robot would be a fantastic third pick for any alliance. With two solidly scoring robots, just pick a third as an annoyer. Well, more than an annoyer. It might deem teams unable to score or balance the bridge since they can see nothing. |
#11
*cough*R08*cough*
#12
Apparently I need to be more obvious with rule-based quotes. I said this an hour ago.
#13
For whatever reason, I misread that as [G08] and that rule was not applicable to a giant blanket. Sorry about that - you were indeed correct.
#14
If I missed a rule that does indeed clearly prevent this idea, please point it out. I can't find anything else in particular but it would be great for future reference. Not to mention I'd never see this idea ![]() |
