Go to Post I GET that FIRST is about more than winning on the field. BUT... ...it is my experience that the great programs of the FIRST world almost always build on a foundation of competitive robots. Success on the field begets success in other realms. - Joe Johnson [more]
Unread 15-01-2012, 23:40
AndresC AndresC is offline
AndresC is an unknown quantity at this point
Image gave my pc bsod
Problem fixed, thank you for the help.
Unread 16-01-2012, 00:07
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Image gave my pc bsod
The images are only designed for the classmate PC. Unfortunately, the only way to fix it is to reinstall windows on your eeePC. Hopefully, you have a restore image for it.
Unread 16-01-2012, 00:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The image on the USB stick contains drivers specifically intended for the Classmate PC. It will not work with any other computer. The correct course of action at this point is to restore your PC to its original state using whatever OS reload media it came with.
To use any Windows PC as a driver station, just install the FRC Utiility and Driver Station updates.
