Go to Post Also, if Beatty fielded a refrigerator we'd still pick them; how can you not - "all they ever do is win". - Gary Dillard [more]
Unread 16-01-2012, 08:44
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Reminder on ARA motors
Teams,
ARA obtained motors may come from a design in which the case of the motor is tied electrically to one of the wires or may actually be the only return connection for the electrical current. A motor with only one wire is a dead give away. Please be sure to measure your motors and insulate the case as needed. This may mean mounting them using polycarbonate, insulated hardware or insulated standoffs. If the case of the motor or attached transmission is plastic, current may flow through an attached metal gear so check that as well.
Thanks from your inspection team.
Al
WB9UVJ
www.wildstang.org
________________________
