Go to Post Yes, you are correct. Even when all other databuses are totally out of bandwith, the PainInTheCalf Bus gets top priority. Good thinking ;-) - Joe Johnson [more]
Go Back   Chief Delphi > Other > Car Nack's Corner
Unread 16-01-2012, 19:03
Joe G.'s Avatar
Joe G. Joe G. is online now
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Car Nack Predicts 12-3
MSC = Michigan State Championship, which has featured quite a high level of play these past few years.
As for Car Nack's prediction, I will be surprised to see 6 robots on 2 bridges. However, I'd wager that 6 on 3 will occur in qualifications at at least 1/4th of regionals, and fairly regularly at the Michigan State Championship, MAR championship, St. Louis, etc.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 16-01-2012, 20:07
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Man! I guy moves to New England and he forgets his roots.
How could I have forgotten Michigan State Championships?
I'm an idiot.
Thanks,
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 16-01-2012, 20:44
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
The best part about Car Nack is trying really, really hard to prove him wrong.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 16-01-2012, 20:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Originally Posted by Joe Johnson View Post
I don't know about Car Nack's prediction but I can tell you that perhaps his thinking not that it is not possible but that the motivation may not be what many people think. For example if Alliance 1 and Alliance 4 both won in round 1 of the elims, by balancing 3 each against opponents that did not balance 3. Then each alliance knows when they meet in that the other can get 40 points -- but it in this case, neither team will choose to do so because they know that if they do, the other team will do... ...so why not keep scoring in the baskets instead?
Joe J.
Because it takes time to setup and balance 3 robots. If you plan to do a 2-balance and keep the remaining robot scoring, it better be a superstar basket scorer with plenty of available balls. Can any single robot make up 20 points in hoops in the time it takes 3 robots to coordinate a balance? I doubt it.
It's like hanging in 2010: sure in some matches you can score the 2 extra points with soccer balls, but in most matches you won't even have 2 balls available to score in the final seconds.
GitHub
Unread 10-03-2012, 00:52
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Originally Posted by Cory View Post
Are you assuming his use of "a" bridge implies the singular?
I wonder if it would be even physically possible to put 6 FRC robots on one bridge. Even piled one on top of another, I think 6 robots would just be too unstable...
On a slightly less hypothetical note, I don't think we can rule out all six robots balanced on 6 bridges ever. There are a lot of matches in an FRC season, and bridge balancing is not all that uncommon, even in weeks one and two. Even last year where (in my opinion) the endgame was much more challenging, four mini-bots did happen a couple of times per regional in eliminations. FRC is too big a place for 6 robots not to happen at least once, in my opinion.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 10-03-2012, 16:08
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Waterford Finals Match 1 just managed TWO triple balances
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016) | FTC Referee (2017)
Academic Student (Forever)
Unread 10-03-2012, 16:14
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Seen here!
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 10-03-2012, 16:25
CalTran's Avatar
Missouri S&T Senior
Rookie Year: 2010
Originally Posted by slijin View Post
Seen here!
Thank you; I was watching over the webcast and I'm STILL in awe over all of the Elimination matches I've seen today. Week two has absolutely stunned me with all of the "records" that have been broken. Teams have broken the 100 point barrier, triple balanced on a regular basis, pulled off a double triple balance, and I'm sure there's plenty more to come. I really can't wait to see MSC, and even more excited to see IRI this year
Unread 10-03-2012, 18:32
jyh947's Avatar
jyh947 jyh947 is offline
FRC #3322 (Eagle Imperium)
Team Role: Leadership
Rookie Year: 2010
jyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to behold
A double triple balance in F1-1 at Waterford Districts!
Congrats to teams 67, 2851, 469, 3601, 3098, 573!
Eagle Emporium: We sell eagle-related products at 50% off!
2012 Rebound Rumble (Elset)
Website Award, Industrial Design Award, Regional Finalist - Kettering District
Website Award, Imagery Award, Regional Winner - Livonia District
2011 Logomotion (Cuddles)
Imagery Award - Ann Arbor District
2010 Breakaway (Seizure)
Rookie All Star Award, Highest Rookie Seed - Ann Arbor District
Rookie All Star Award - Troy District
Unread 10-03-2012, 20:30
Patrick Seeney Patrick Seeney is offline
Patrick Seeney
FRC #0469 (Las Guerrillas)
Rookie Year: 1999
Patrick Seeney is an unknown quantity at this point
Thumbs up Re: Car Nack Predicts 12-3
Thanks to 67, 2851, 573, 3098, and 3601 for a great finals and pulling off the first double triple of the season!
Unread 10-03-2012, 20:36
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
The crowd went wild when it happened, I'm sooooo glad I was there to see it.
Car Nack appears to be 0-2 is he slipping up?
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 10-03-2012, 20:39
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I believe the basketball term is a triple-double...
I also think that Car Nack needs a new crystal ball.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-01-2012, 11:42
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
Team Role: Mechanical
the man is on a distinguished road
I think there will be. Especially in qualification matches. Two on each bridge wont be terribly difficult.
Every day is a new adventure!!!
Unread 20-01-2012, 15:59
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
I'd be disappointed if there was a regional where it never happened. I do think it'll be harder than a lot of people think, but considering the rewards for being able to balance, teams will be crazy to design a robot that can't balance with at least one other.
Does anyone else remember when TBA signatures actually worked?
  #15   Spotlight this post!
Unread 20-01-2012, 16:14
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is online now
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Well remember, in qualifications, this would be balancing 2 robots on each of the three bridges. But in quals, how often will there be 6 robots playing together that are capable of balancing with another robot?
Then in eliminations, you need to have two alliances that can balance 3 robots on their alliance bridge since there is no reward for the coopertition bridge. Having never seen any of the robots attempt a triple balance in quals because that would be useless, the farthest you can go in selecting for a triple balance alliance is finding robots that can consistently balance with 2 in quals and will all fit on the bridge together. Now have two alliances that have selected for that face each other in eliminations and pull off a triple balance in the same match...with next to no practice together doing it.
Steep odds either way, but I could see it happening at qualifications at Championship, MSC and IRI, otherwise the odds are far too slim.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
