Go to Post Fame... Fortune... Bleh I'm inspired and thats all that matters to me - Noah Melamed [more]
Unread 16-01-2012, 13:08
Jecht22 Jecht22 is offline
2012 Team President
AKA: John Springer
FRC #2522 (Royal Robotics)
Team Role: Mechanical
Jecht22 is an unknown quantity at this point
Andy Mark Super Shifters
Hey I wanted to ask a few questions to the teams who have used the andy mark super shifters before. Does it make a big difference to shift them using pneumatics or servos. Assuming the answer to this question is that pneumatics will be better, is it possible to use electrical solenoid actuators instead.
Unread 16-01-2012, 13:12
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Re: Andy Mark Super Shifters
The pneumatic shifting is definitely better. When you only have 120 seconds to play with, if shifting takes 1-2 seconds, it is wasted time. You also might have to stop driving to shift. With pneumatic, it is instantaneous.
The only downside to pneumatic that I can see is the requirement that you have to have a compressor and added weight. Though, if this is the only pneumatic thing on there, you may be able to get away with pre-charging some tanks.
Unread 16-01-2012, 13:31
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
It might be, but the performance won't be the same as pneumatics.
R48J limits you to Solenoids rated at less than 10 Watts continuous duty:
electrical solenoid actuators, no greater than 1 in. stroke and rated at no greater than 10 watts continuous duty at 12V
A quick look at McMaster-Carr shows that all their solenoids meeting that rule have a maximum force of less than or exactly 5lbs.
In contrast the 3/4" bore pneumatic cylinder recommended by andymark has a force of about 25lbs.
Also, designing mounting brackets to interface the solenoid with the shifter will be an annoyance.
Unread 16-01-2012, 13:40
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Team RUSH, FRC27, has used servo shifting on our SS transmissions since 2008 without incident.
We shift on the fly with no issues. We couldn't be happier with it.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 16-01-2012, 21:11
DonRotolo's Avatar
Back to humble
FRC #0832
We avoid servo shifting because it is a little sluggish. But it is reliable enough.
Unread 16-01-2012, 21:58
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I'd go for the pneumatics if your weight can give up all of those components, but don't anticipate your robot will make a giant decline in quality if you go with the supplied servo.
AndyMark knows it's reliable enough to include it in the package. They don't ship bad stuff. (Here's to you, RS-775s!)
Unread 16-01-2012, 22:16
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
McMaster 69905K85 10w continuous duty is rated at 60 lbs.
Unread 16-01-2012, 22:20
Captaindan's Avatar
Captaindan Captaindan is offline
AKA: Daniel
FRC #0364 (Team Fusion)
Team Role: Driver
Rookie Year: 2010
Captaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the rough
they are definitely the way to go as far as transmissions we have gone with both methods of shifting with no problems
Unread 16-01-2012, 22:40
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
pneumatic is definitely the way to go
if u go with this cylinder you also use half the air and if for some reason your pneumatic system fails it will lock you in low gear instead of in between gears
http://www.andymark.com/product-p/am-0591.htm
last year we used the super shifters with encoders and had automatic shifting using Hysteresis . it made a huge difference
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 16-01-2012, 22:55
Easton8's Avatar
Easton8 Easton8 is offline
AKA: Alex Hallberg
FRC #0008
Team Role: CAD
Rookie Year: 2011
Easton8 is an unknown quantity at this point
if you're using servo shifting you robot will take a few seconds to shift, and the robot can't be moving. That takes away valuable time that you could be using to be scoring or doing other things. Pneumatic shifting is faster (takes less than a second), and you can shift while your robot is driving at full speed. Unless your team insists on not having pneumatics in your robot for some reason the pneumatic shifting is most definitely the preferable method.
Unread 16-01-2012, 23:04
AKA: Simon Bohn
Rookie Year: 2010
What is Hysteresis?
Pneumatic shifting broke our SuperShifters. Go with servo.
We've been using our supershifters with pneumatics all of last year, and have had no such problems. Care to elaborate?
Unread 16-01-2012, 23:16
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
The locking pin, or whatever it is, that connects the shaft to the rotating thingy with the piston inside it broke; We think it's due to shifting at full power while not having the gears in motion.
After replacing (or something or other) the pin and adding quite a bit of glue (loctite? I wasn't really watching when they were fixing it), and lowering the pressure going to the pistons by means of the regulator, this hasn't happened since.
Note: This happened to BOTH SS's while they were on the robot and we were testing them.
Attending: MN Duluth Regional
Unread 16-01-2012, 23:17
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I think some teams had trouble with shifters last year, but it wasn't the pneumatics. It was roll pins that were not quite durable enough, which has since been fixed, IIRC.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-01-2012, 23:48
cmwilson13's Avatar
Hysteresis is a programming term i don't know the technical definition but it prevents the pistons from shifting very rapidly between high and low when you are right at the speed at which the transmission shifts up and down.
a very simple Hysteresis is to have them shift up at say 5 ft/s but shift down at 3ft/s which prevents the chattering which occurs if u shift up and down at the same speed.
as for the super shifters breaking if you use pneumatics that was a specific problem m in last years supper shifters they changed a roll pin to a screw and the screw could not handle the stress and would fail. we had a roll pin in ours and with the auto shiting we shifted anywhere from 20-50 times a match depending on how much we started and stopped and never broke a super shifter
we where also shifting at 60 psi all season.
edit:http://en.wikipedia.org/wiki/Hysteresis#Control_systems
  #15   Spotlight this post!
Unread 16-01-2012, 22:52
Rookie Year: 2007
It's rated for 60 oz which is 3.75 lbs.
