Go to Post Back in the old days, we didn't have clues, and we liked it! - Joe Ross [more]
Unread 01-16-2012, 03:44 PM
Dripto Dripto is offline
AKA: Dripto Debroy
FRC #0694 (StuyPulse)
Team Role: Student
Dripto is an unknown quantity at this point
Question Ideal compression for flywheel?
Hey guys, I'm currently designing a flywheel shooter, and was wondering if there were any guidelines to how much compression to aim for. Increasing compression increases both the normal force of the ball, and the deformation, which leads to more contact area, however it also relies more on the inconsistent compression of the balls, so I would like to not have excessive amounts.
At the moment I am aiming for about 1.5" to 2" of compression on the ball, do you think this would be acceptable?
The ball will be in contact with the rollers for about 12.5" of travel. (Approximate Center of Mass travel)
Thanks for your help!
Unread 01-16-2012, 03:57 PM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Ideal compression for flywheel?
Honestly, I would only recommend as much compression as you need to get the width of contact patch your shooter requires, and no more. If you have high speed AND high normal forces, you might repeatedly leave marks or scuffs on the ball. This is illegal per [G12]. Additionally, the force required to compress the ball will cause the flywheel to slow.
We're getting repeatable results with much, much less compression.
GitHub
Unread 01-16-2012, 04:01 PM
AKA: Dripto Debroy
Team Role: Student
So you're saying just compress enough to have a firm grip on the ball?
Unread 01-16-2012, 04:02 PM
JesseK's Avatar
FRC #1885 (ILITE)
Why would you compress it any more than what you need? What advantage do you gain in power or precision by compressing the ball? Ergo, compress it only as needed. There's no specific amount; it will take prototyping. My recommendation is to measure the ball uncompressed, push it in with your palm to compress it just until the contact patch firms up a bit, then measure again. Start with that, then adjust in small amounts for your specific shooter.
GitHub
Unread 01-16-2012, 04:08 PM
AKA: Dripto Debroy
Team Role: Student
Fair enough, I'll go redo my measurements.
I was just a little worried about having the ball start sliding, but if that isnt an issue there's no reason to compress excessively.
Unread 01-16-2012, 10:28 PM
Easton8's Avatar
Easton8 Easton8 is offline
AKA: Alex Hallberg
FRC #0008
Team Role: CAD
Rookie Year: 2011
Easton8 is an unknown quantity at this point
Prototype a design that has an adjustable compression (example: http://www.youtube.com/watch?v=DO0XzkthMUs), and find what works best for you. A pitching machine design I built achieved accuracy up to about 20' with roughly 2.5-3" of compression. That being said, most shooters are different so it will take prototyping to find your ideal compression rate.
Unread 01-18-2012, 02:19 PM
Kenyow's Avatar
Kenyow Kenyow is offline
Kenyow
FRC #3620 (Average Joes)
Rookie Year: 2011
Kenyow is an unknown quantity at this point
I will be doing some tests on the ball today to find out how much force it takes to compress the ball X amount, and how that relates to the torque required on the motors running the shooter. I will try to post the results on this thread later. Maybe as a formula. Stay tuned!
Unread 01-18-2012, 03:00 PM
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
We've done similar testing and come up with interesting results. Good luck!
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 01-18-2012, 04:52 PM
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
I did some testing yesterday. it appeared the ball had about 7 lbs/inch of compression, this was pretty linear up to 3 inches where I stopped measuring. This was between two flat surfaces though, so i'd expect a different (lower) value if you had a single wheel or were riding on rails with the ball.
I wonder how this compares to other teams measurements?
Unread 01-18-2012, 09:13 PM
Kenyow's Avatar
Kenyow
Rookie Year: 2011
As promised, here are the results of the tests on ball compression. And how to use them. I took a pressure plate and placed the ball on top, and rigged a system where i could lower a surface in half inch increments and measure the force on the ball. Here is what i got. I would encourage other teams to try it out for themselves.
0.0in 0.0 N
0.5in 22.3 N
1.0in 45.8 N
1.5in 66.5 N
2.0in 90.4 N
2.5in 112.6 N
3.0in 127.6 N
If you want to know the torque needed on the motor, use this formula:
Torque = Force of compression X Radius of the shooter wheel X The compressed coefficient of friction between the ball and the shooter.
Hope this helps
Unread 01-19-2012, 04:42 PM
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
-Brando
Please share !!!! Would be good to see if two teams can get similar results.
Unread 01-19-2012, 04:57 PM
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
we have a 1.5"-2" compression for our shooter prototype and we found no real difference between that range.
1" didnt have as much distance/power as it left our shooter through repeated tests.
Different designs will have different optimal compression requirements.
Best to test it out and see for yourself what will work best.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 01-19-2012, 05:05 PM
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
We determined experimentally that 1.5" of compression with nominally 1.5" diameter rollers worked pretty well. It is encouraging to see other teams getting the same numbers!
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
