Go to Post The 48 defensive DNA lies dormant in the drive train. It's impossible to forget. - Koko Ed [more]
Unread 16-01-2012, 19:13
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Wireless Programming
A rookie team I'm mentoring (therefore with the 2012 cRio and DLink) is attempting to program the cRio wirelessly, but is having trouble.
We are properly configured and able to program by wiring directly into cRio, and are able to communicate via Dashboard wirelessly. However, when we attempt to Deploy (using LabView) when connected to wireless, LabView does not detect the cRio.
Has anyone run into this issue? Is it actually possible to program the cRio through the AP?
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 16-01-2012, 19:21
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
Re: Wireless Programming
I have been able to successfully deploy code to the robot wirelesly. However, it isn't advisable because a loss of signal could cause undesirable operation. I would say just stick to the ethernet cord for best results.
Unread 16-01-2012, 19:28
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
You can program wirelessly through the AP, we do it all the time.
Did you properly set the projects IP address when you created it? When you first create a project you set the ip adress as 10.x.y.2 where x.y is your team number.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 16-01-2012, 19:30
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
I dont program in labview i do it in Java all the time been doing it since the cROP has been our platform. I would suggest check your wireless network adapter setting. They need to be on the robots network 10.te.am.xx
Unread 17-01-2012, 01:58
seg9585's Avatar
AKA: Eric
Yes, the IP address is set correctly in the LabView project. We will try again tomorrow and report on status, as we programmed on a different computer than we ran our dashboard on (Classmate), so I will need to re-check the computer's LAN config.
Either way, thanks for reporting that it's possible, I didn't want to attempt to chase this and then find out it wasn't do-able.
My FIRST legacy:
Unread 17-01-2012, 02:06
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Is the IP address for the wireless network settings on the COMPUTER set correctly? (the computer you're downloading code from) In other words, is your wireless adapter/card/settings set just like you must have set your wired/LAN settings?
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 17-01-2012, 10:06
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Program using a tether, yes it is less convenient but its a faster connection and less chance of interference from other wireless connections. This will also be the way you MUST tether in the pits in competition, so its better to get in the habit now. If you program wirelessly you may have a chance of corrupting the program requiring you to re-image the CRIO.
Unread 17-01-2012, 10:21
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
The only time we ever program with a wired connection is either in the Pits or when we are re-imaging the cRIO. We hardly ever have a problem with interference and have never had an issue where we had to re-image the cRIO because of any data corruption.
When this ability first came out I was skeptical and we had some issues then, but there has been a lot of work done to our control system to help make this option (in my eyes) the best option.
EDIT: We've only ever had 1 problem with interference. This was at the St Louis Science Center during a demonstration event. We had 6 FRC teams controlling their robots wireleslly along with many Science Center wireless networks as well. One of the Science Center networks was causing this problem and the next time we did a demo they had it turned off and we didn't have any problems at all.
