Sending data to cRIO
Is it possible to send data to the cRIO from a Java program through a socket or the like? I would like to outsource some heavy operations to a more powerful computer. If possible, is there examples of both the host and cRIO code?
Re: Sending data to cRIO
Yes
See javax.microedition.io http://k.thekks.net/frcdoc/javax/mic...e-summary.html You can even have your server on a laptop written in a completely differnet language (I'm doing python) |
Will a SocketConnection be sufficient? For the host, which IP do you put? I tried a quick example, and i get a connection refused exception.
To simplify development and comply with standards, I think ill setup a restful server on the onboard computer instead of handling raw sockets. My experiences with raw sockets are all really bad.
I would recommend the same thing for you. This way you only need to use the httpconnection class |
You mention onboard computer so I assume you are putting a separate computer on the robot. Have you thought about using a null-modem cable and a serial connection? The cRIO appears to have raw serial support and the serial port is generally quite simple to use - lots less machinery than even a restful server and HTTP. Most good serial apis (and I know there is at least a few good Java ones) let you send and receive a variety of data types. Worst case scenario would be to use strings. I know the cRIO can send bytes as well as use things like printf with the serial port.
-Mike |
I still think restful will be the simplest. I don't when need to write any connection software (like 10 lines)
For my own understanding then would you run a web server on the computer and make HTTP calls from the cRIO? And if so, what is the code on the cRIO to do that? I see minimal WPI documentation on socket and nothing on HTTP. Even a link to the right documentation would be enough to get me started. Thanks!
-Mike |
Yeah, you're right. I initially planned to use a purely standard compliant restful server. However, I think I might just go with flask as it will be super easy to program for and I already have a LOT of experience with it. On top of flask, I'll probably have code to pull off the camera image from its HTTP stream, and use OpenCV to process them. Those results returned by the processor will be added to a queue (by POSTing to the flask server), which then the cRIO could pull off from a GET request to a specific address. Since flask's dev server is not the ideal choice for high traffic concurrent application (not exactly it, but it'll be more than 20 req per second.. for sure), I'll probably setup a gevent wsgi server to wrap that around the flask app, which I already have code for that I've written for other applications. The only non-problem I have with this is the overhead of message delivery.. but those are really nothing since everything is either local or over an ethernet cable.. transferring some simple JSON data, and gevent is fully equipped to handle those. I feel like someone is going to call this setup too complicated.. but it's fool proof, there will be little to no errors in the server/client code as the only ones that has a chance of occurring is some sort of connection error (or a bug in the library.. but i doubt that).. which will occur with socket anyway. If someone is going for the same approach, I'll be happy to share my client and server code. Last edited by shuhao : 22-01-2012 at 14:43. |
Gah, I totally lost track of the fact you are using Java. We are using C++ and I have no idea how the students are going to get C++ to talk to anything effectively. Serial was a crap shoot and still is. I REALLY wish we were using something else.
-Mike |
#10
If you're sending data between the cRio and a laptop on the robot (connected to the bridge or 2nd cRio ethernet port), it would seem that UDP datagrams are the simplest solution, as they are easy to implement (a UDP listener does not require more than one thread, and a UDP sender is a synchronous call requiring no state at all)
#11
The problem is getting students that barely know C++ far enough along to actually put that together. With Java at least I could point to hundreds of cut-and-pastable examples. I think we will probably stick with the original serial idea just for it's general simplicity.
-Mike |
#12
For me though, I don't think Copy-Pasta is the best idea in terms of programming the robot.. the students will neither learn, nor will the robot be well programmed... Edit: Just took a look at the C++ references (stupid chm files.. gotta find a viewer lol) and it seems your options is fairly limited.. existing C++ code probably won't work for you either. Also, are you a mentor on the team? Last edited by shuhao : 22-01-2012 at 15:06. |
#13
C++ was the language the students wanted as they picked it last year and it worked for em. There are two differences to last year though - they had one student on the team who was OK at C++ and the robot code was vastly simpler. They have no C++ mentors that have shown up regularly and while I'm actually a good programmer, I don't know C++ goop well enough to help significantly.
-Mike |
#14
Learning to use UDP can be an opportunity to look at Java or LV examples and let the kids translate it to C++, or at least try to. I agree that C++ copy and pasting code is not a great learning environment, especially if there isn't a mentor there to help debug and help fix things.
Greg McKaskle |
#15
For those people who are interested, I just took about 30 minutes to write up the server code for messaging:
https://github.com/FRCTeam4069/Mediator |
