Go to Post I mean I am a pocket protector kind of guy. - techhelpbb [more]
Unread 17-01-2012, 11:03
2508 2508 is offline
FRC #2508
2508 is an unknown quantity at this point
Displaying Data on the Front Panel
I have searched for this and I must be using the wrong search terms because I can't find anything helpful. I would like to display data to the driver in the form of an LED notifying the driver of the status of some boolean value in a sub VI. Anyone know how this is done or where I can find information about this?
Unread 17-01-2012, 11:32
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Displaying Data on the Front Panel
Three ways to accomplish that:
  1. Use the Dashboard as a virtual LED. It already has examples of that.
  2. Use the Cypress First Touch connected to the Driver Station PC to power a physical LED (WPI Robotics Library->Driver Station->Compatibility IO->Set Dig Out)
  3. Use the Driver Station application I/O tab to see the virtual LED associated with the Cypress.
Cudos for searching first.
It's understandable that the information might be hard to search for when you don't know the custom terms we use for it.
Unread 17-01-2012, 11:40
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
I don't think he means a physical LED, just one on the driver station. You'll have to send data back and forth from the DS. There should be labview examples provided for doing this. I will look it up for you right now.
Unread 17-01-2012, 11:58
Flywheel Police
Have you created a dashboard project and tried to step through the code and see how it works? You'll basically need to attach the data to the dashboard sending vi's in your robot code and pull them out of the array in your dashboard project. Take a look at Tutorial 6- Creating a Custom Dashboard.
