Go to Post I would like to complain about the game as well. Complain, complain. - Monochron [more]
View Poll Results: What weight is your team shooting for?
Will go out of way and add material to make the robot 120 lbs. 46 35.94%
Will shoot for 120 lbs, but will not necessarily make it. 26 20.31%
Going for the lightest robot possible. 25 19.53%
Not shooting for any specific weight. 26 20.31%
Other 5 3.91%
Voters: 128. You may not vote on this poll
Unread 17-01-2012, 11:49
crimsonjake's Avatar
crimsonjake crimsonjake is offline
AKA: Jake Westerberg
FRC #2526 (Crimson Robotics)
Team Role: Leadership
Rookie Year: 2011
crimsonjake is an unknown quantity at this point
Robot Weight
Just wondering how many teams will be shooting for the 120 weight limit! With the bridge being as tight as it will be with either 2 or 3 robots, I was thinking that all the robots on the alliance will need to be relatively the same weight.
Unread 17-01-2012, 11:54
Polaris395's Avatar
Polaris395 Polaris395 is offline
FRC #2537
Polaris395 is an unknown quantity at this point
Re: Robot Weight
I think it will be pretty safe to assume that everyone is +/- 10 pounds from 110lbs.
___________
University of Delaware 2015
Chemical Engineering
Johns Hopkins University Applied Physics Lab
Software Engineer
http://jhuapl.edu
FRC 2537 - RAID
Atholton High School
Consultant/Graduate
http://first.raidtech.net
Unread 17-01-2012, 12:02
Rookie Year: 2011
Re: Robot Weight
That's what I'm hoping. With the point value of 3 robots on the bridge in the elimination rounds it could be a game-changer, but the bridge size may hold a lot of alliances back. Even if all the robots on the alliance are built "the short way," balancing will be hard to coordinate unless they are all weighted the same. I haven't done the calculations as to how much leeway we get, but I'm assuming it is pretty small.
Unread 17-01-2012, 12:06
AlecMataloni AlecMataloni is offline
Excellence is Bliss
FRC #0111 (WildStang)
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Re: Robot Weight
Where's the "drill enough weight holes so we're barely under 120lbs" option?
Unread 17-01-2012, 12:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Weight
We're shooting for making the "upper" part of the robot as light as possible, and we're not concerned about the bottom part. But we'll make sure it's less than 120 on bag day
Unread 17-01-2012, 12:21
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Robot Weight
It might not be a bad idea for a team to make their robot weight adjustable. Have some way to increase/decrease your weight by ~1 lb increments so you can match your alliance partners. "Our weight is adjustable. Robot A goes in the middle, we'll go opposite robot B and we've already calibrated our weight to 117lbs to match". Say that to a potential alliance before eliminations, and it could sway them to picking you!
Unread 17-01-2012, 12:25
Rookie Year: 2011
Re: Robot Weight
Another thing that could play a factor (a very, very small factor) would be the unequal distribution of weight upon each wheel.
i.e. the front of the robot has more weight on its wheels than the back.
Just to keep in the back of your mind!
Unread 17-01-2012, 13:40
MrForbes's Avatar
AKA: Jim
Re: Robot Weight
We'll definitely do this, we will rearrange where things go to keep the center of mass centered between the front and back. Side to side is not too much of an issue....since we're planning a "wide" robot.
Unread 17-01-2012, 13:53
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: Robot Weight
As we understand this game, it's about speed. We'll keep our robot as light as possible. With a 35x27 frame and 8" wheels, we ought to be able to 'spin' on the bridge and change our orientation to perpendicular to the bridge, allowing our partners to climb up on the ends.
Hi!
Unread 17-01-2012, 16:10
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Rookie Year: 2011
Flimsor will become famous soon enough
Re: Robot Weight
We'll be shooting for lower than 120 but you always seem end up at the limit.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 03-02-2012, 19:35
DarkByakko's Avatar
DarkByakko DarkByakko is offline
Winner
AKA: Sam
FRC #3461 (Operation P.E.A.C.C.E.)
Team Role: Driver
Rookie Year: 2011
DarkByakko is an unknown quantity at this point
Re: Robot Weight
Our team is on the fence with this. Assuming the majority of the teams competing are shooting for a weight near or equal to 120 lbs, we're more comfortable trying for a heavier bot due to the inevitable fact that if there are more heavy bots competing, a light bot would be pushed around.
We had this problem in the last competition, wherein our bot was lighter than the others, and the other heavier bots tended to push ours right out of the way.
It's a hard decision to make; sacrifice endurance for speed, or increase the weight for steadier shooting at the cost of a slower robot.
Unread 06-02-2012, 08:14
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
Re: Robot Weight
With over 120lbs on one end of the bridge, how can the third robot even attempt to lower the other end of the bridge? Unless you can easily be pushed sideways I dont see this as a possible solution.
Unread 17-01-2012, 12:22
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
Team Role: Coach
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: Robot Weight
We're with Squirrel. Low center of gravity is going to be critical when traversing the ramp so as long as our weight is at the bottom of the bot we're happy. Probably going to be close to the 120 but not neccessarily shooting for right at it.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 17-01-2012, 12:29
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Team Role: Teacher
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
Re: Robot Weight
Or: "My hacksaw is my best friend..."
  #15   Spotlight this post!
Unread 17-01-2012, 12:35
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Re: Robot Weight
We'll build the entire robot as light as possible, then add solid steel to very bottom until we hit 120.
