Go to Post 1/4" baltic birch plywood is most of our metal. - z_beeblebrox [more]
Unread 17-01-2012, 12:46
MikeS23 MikeS23 is offline
AKA: Michael Sepanik
FRC #0904 (D Cubed)
MikeS23 is an unknown quantity at this point
PID Controller
Okay so ive been messing with one of our test robots and i noticed that some of the motors are going faster than other motors i was wondering how to implement a PID controller using Encoders to make all of the motors run at the same frequency can someone show me an example of some code in labVEIW of how to do that?
Unread 17-01-2012, 13:58
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Re: PID Controller
Do you have the capability to do CAN? If you do, you can simply use the jaguar's built-in PID controls. You initialize all of the motors and apply their PID values in Begin.vi, and the encoders plug into the Jags. This also reduces the number of PWM cables running around your robot!
Unread 17-01-2012, 14:33
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: PID Controller
Have you ever successfully tuned the Jag's speed controller for a drivetrain?
If so, please share your experience here:
http://www.chiefdelphi.com/forums/sh...d.php?t=100135
Unread 17-01-2012, 17:14
FRC #0904 (D Cubed)
Re: PID Controller
for the robot im doing this on it has all victors but thanks i can use that for this years robot
