Go to Post Sustaining an FRC team is really hard! - Jared Russell [more]
Unread 17-01-2012, 15:31
rbyrne15 rbyrne15 is offline
FRC #2877
rbyrne15 is an unknown quantity at this point
Direct Drive Launcher Motor Help
Hey guys, we were wondering what would be the best way to directly power a wheel that will be mounted on our launcher. The motor will be a Bane Bot with a rs775-18 planetary gearbox. The wheel is a 4 inch plaction off Andy Mark.
Any suggestions for hubs, axles, etc. would be greatly appreciated.
Thanks,
Ryan
Unread 17-01-2012, 15:34
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Direct Drive Launcher Motor Help
AndyMark has a set of hubs that would fit the plaction wheel: http://www.andymark.com/Hubs-s/215.htm
You can get couplers and a longer shaft of McMaster to extend the shaft from the gearbox, which I believe is an 1/2 inch keyed shaft.
We are doing something similar but using the CImulator gearbox.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
