Go to Post I wish I had two extra hands, so I could give those gearboxes four thumbs up! - Billfred [more]
Unread 17-01-2012, 16:36
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
Team Role: Mechanical
cbeavers6790 will become famous soon enough
outside the frame perimeter limit question
I know that you can only extend a Max 14 inches outside the robot but I have a more specific question. Ourpossible shooter is currently being drawn to rotate 180degrees 90 each way. When turned all the way it extends 7 inches outside one way but 1 inch on the other side. Is this legal? It is all the same thing but it would go outside the frame on two sides
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 17-01-2012, 16:58
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: outside the frame perimeter limit question
G21:
Robots may extend one appendage up to 14 in. beyond a single edge of their frame perimeter at any time.
Violation: Foul for exceeding size allotments; Technical-Foul for continuous or repeated violations.
Emphasis mine. If your mechanism is extending beyond multiple edges of your frame, it is not legal.
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
edit* forgot G21
Unread 17-01-2012, 17:00
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
From what I have read this would not be legal due to the fact that you are extending beyond the frame perimeter on two sides of your robot simultaneously. According to rule G21: "Robots may extend one appendage up to 14 in. beyond a single edge of their frame perimeter at any time."
www.sharkattack744.com
