Can you send us more 8-inch lawn-mower wheels? The hubs were bent during fabrication, and they will not spin on the center.
-Thanks Team #224 |
If you are local, you can contact Mr. Martus and get new wheels.
If you are not local, it may be quicker to order them directly from McMaster.com page 1124 Part number: 2331T53 Description: Welded Rim Semi-Pneumat Wheel W/Ball Bearings 8" Dia X 1-3/4" W, 1-3/8" Off Hub, For 1/2" Axle, 60#Cap Good luck. Joe J. |
| What do you use for wheels? | Andrew | Technical Discussion | 36 | 08-01-2004 10:20 |
| Good or bad: back wheels coming off the ground | Gui Cavalcanti | Technical Discussion | 2 | 17-03-2002 22:09 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Question about wheels | Randy_Ai | Technical Discussion | 9 | 24-01-2002 17:14 |
| Skyway wheels w/o bearings | ahecht | Technical Discussion | 4 | 22-01-2002 01:25 |
