Go to Post Even though others have had success, I will be honest, this method sort of creeps me out. - Joe Johnson [more]
Unread 17-01-2012, 20:37
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
How to mount hub to window motor?
Hey guys, was wondering how you attach the black window motor hub to the window motor, i know they slip on fine, but what keeps them from coming off? Do i have to drill my own set-screw or something?
Unread 17-01-2012, 22:07
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: How to mount hub to window motor?
You can do it that way, just don't drill too deep as the white plastic part that spins rides on a steel pin that doesn't spin. It doesn't take much to hold the black adapter on. We used pressure to hold them on last year. By using a shaft that is inserted in the other side with light pressure applied from a bearing opposite the motor.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 17-01-2012, 22:50
AKA: Josh
FRC #2075 (Engima)
Thanks
Unread 17-01-2012, 23:15
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
We found the easiest way to keep them on their is to get a star clip and push it into the metal pole after the hub is inserted. One start clip is used on the cim to hold a gear on it. Something similar to that. You may need a different size though
