Go to Post It's wrong to scuttle someone else's boat because you don't think it's seaworthy. You probably don't know that what you were seeing will be called a submarine. - ThatHat [more]
Unread 18-01-2012, 00:38
CompSciGeek CompSciGeek is offline
FRC #0948
CompSciGeek is an unknown quantity at this point
Swerve Drive
So I'm a little confused. Our team, as far as I know, has almost never used swerve drive before. We are making the full omni type that has 8 motors(4 for drive, 4 for the angle) to allow for independent angles on each wheel.
EDIT: Never mind, I realize that my code actually never uses RobotDrive wow lol
Also, what's the default number of channels for every slot in a Jaguar?
