How fast can KOP encoders count?
We wanted to track the live rpm of our ball shooter shaft, turns about 5500 rpm max, could a 250 or 360 count encoder count that fast? (198000 counts per minute) (33000 counts a second) (using a 360 count.) Anybody know where we could find a single count encoder wheel (1 count per rev.), or could the software keep up at 33000 counts a second?
Re: How fast can KOP encoders count?
The true limit on encoder counts is the cRIO. I don't know the official upper limit, but Austin Schuh on 254/971 has quoted me that a 64 count encoder on a CIM 1:1 (5300 rpm) works. This is ~5600 counts/second. For velocity control at such speeds, you really don't need that many ticks per second. A single "tick" encoder could be made with various forms of light sensors, hall effect sensors, etc... |
Sweet! Anybody know where I could find a 64 count or less encoder?
In this case I think a hall effect or light sensor packaged right is a much cheaper option with plenty of accuracy.
A light sensor can be made into such a sensor by merely making the surface of your wheel an encoder disk of sorts. For example, if your shooter wheel is white/light colored, put 1-2 lines of black electrical tape on it. If it's black, do the opposite. Far, far cheaper. You'd wire it as a single phase (not quadrature) encoder and just set the ticks per rotation to 1-2 (whatever you install on it). |
On the NI FIRST community, Joe Hershberger said the limit is 39,987 counts per second. https://decibel.ni.com/content/message/12523 All of this is handled by the FPGA, so there is no additional processor load as you increase the count rate.
Joe made one important caveat, that there is a perfect 90 degree phase relationship between the signals from the encoder. This isn't true with a real world encoder. I would leave 50-100% margin and only use a range of 30-20k counts per second. |
We used a motor as an analog tachometer, instead of an encoder, the last time we did this.
Could you (have one of your students) submit a CD whitepaper on this? I'd be very interested to hear their thoughts on it and see the exact setup. |
http://www.team358.org/files/electri...Tachometer.pdf It never made it to CD whitepaper posting for some reason... It's still working. We were using it the other night. |
As a side note the analog inputs can handle +/- 10V, so you could loosen the resistor divider, ditch D1 and replace D2 with something bi-directional. |
#10
You could use a simple LED/Photodiode pair with the spokes of the wheel to break the beam. Should be very reliable and assuming 6 spokes, gives you 6 pulses/rev. |
