Go to Post I think this thread needs a reminder that there's no h in mecanum. ;) - Lil' Lavery [more]
Unread 18-01-2012, 16:44
DiedandLived DiedandLived is offline
FRC #3236
DiedandLived is an unknown quantity at this point
No Robot Code on Driver Station
If anyone could help that would be great!
  • Using Windriver
    Updates currently installed: Workbench, utilities, and driver station
    Driver station displays connection and shows the firmware v43 is currently installed on cRio
    We hit deploy on First<Deploy when using Windriver
    No errors and displays in bottom - successfully deployed
    We have checked in cRio and found the file
On Driver Station
  • Robot connection light green
    Robot Code light still red (not found)
    Continuously connects then disconnects
Unread 18-01-2012, 17:47
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
Rookie Year: 2007
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: No Robot Code on Driver Station
Try running a kernel task instead of deploying it and seeing if you get any errors such as an Unresolved Symbol. Are you using the new Command based methodology?
Unread 18-01-2012, 18:09
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Get a target console up, and you should see some errors.
An easy one this year is if your modules are in the wrong slots. Whereas the digital sidecar was cRio slot 4 last year, it is now slot 2.
Slot 1: Analog
Slot 2: Digital
Slot 3: Solenoid
Unread 19-01-2012, 20:25
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
Rookie Year: 2010
enrique will become famous soon enough
Send a message via Yahoo to enrique
Go to window then Preferences and under First Downloader, make sure your team number is there and the path to your executable.
