Go to Post If you don't manage weight from the beginning, weight will manage you at the end. - charrisTTI [more]
Unread 18-01-2012, 19:47
gammabase gammabase is offline
FRC #3328
gammabase is an unknown quantity at this point
AndyMark Chassis Chain Clearance Issue
After assembling the AndyMark 6-wheel drive chassis, we found that the chain from the Cimple box to the wheel was grazing the wheel by quite a bit. We've checked the instructions multiple times for mistakes, but so far it seems like we've done everything right. Does anybody else have this problem, or a solution to it?
We are going to try cutting and rearranging the white spacers on the wheel axle if nothing comes up.
