Go to Post I'm looking forward to January when things will slow down some! - Foster [more]
Unread 18-01-2012, 22:12
gman892's Avatar
gman892 gman892 is offline
#2785
FRC #2785
Team Role: Mechanical
Rookie Year: 2011
gman892 is an unknown quantity at this point
Lightbulb 2785 Drive Train- Border Hopping Capabilities
Hello,
I am a new member of Chief Delphi and also a Co-Captain of Team 2785.
Being in charge of the drive train among other things, I finished the prototype today and have a video of it climbing over a modeled barrier of Rebound Rumble.
http://www.youtube.com/watch?v=xcI2L6HyDQc
The actual Chassis is planned to be constructed out of 1" 8020, but same design with chain driven toughboxes. I just wanted to Post here and look for some feedback, comments, suggestions, and constructive criticism.
Would it be better for each toughbox to be powered by two CIM motors?
Would some sort of ski on the undercarrage help slide the robot over?
Any way to make the design more reliable?
I appreciate your time!
Thanks!
Best,
Team 2785
Unread 18-01-2012, 22:17
jdunston94 jdunston94 is offline
FRC #3357 (C.O.M.E.T.S.)
Rookie Year: 2011
jdunston94 is a jewel in the roughjdunston94 is a jewel in the roughjdunston94 is a jewel in the roughjdunston94 is a jewel in the rough
Re: 2785 Drive Train- Border Hopping Capabilities
what is the diameter of a wheel you are using?
Unread 18-01-2012, 22:19
gman892's Avatar
#2785
FRC #2785
Rookie Year: 2011
They are the standard Grey Wheels from the KOP of years past. 8" diameter.
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder
AKA: noops
FRC #1648 (G3 Robotics)
Team Role: Team Spirit / Cheering
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I only see 4 wheels on that robot. Unless it's a wide robot or you are using slick wheels, it won't turn well. Quoted from experience. We foolishly used 4 wheels on a long chassis last year. Never again....
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
RIT Graduate Student, CompE
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
I'd caution you to try that again with 120lbs of weight before you build it into the final design.
Unread 18-01-2012, 22:21
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Good job so far!
Definitely try it out at full weight at an estimated center of gravity as your results may change.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 18-01-2012, 22:24
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
Mentor
AKA: Clint Ott
FRC #1011
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Definitely load it up like everyone else said. But more importantly make sure you test everything on carpet as well. I hate to see teams go into competition with long base four wheel drives and have to either switch one set to slick wheels or omnis because they just can't turn. It looks like you have moved the wheels closer together. This may help some but I doubt it will be enough.
Keep up the good work otherwise.
Unread 18-01-2012, 22:28
KevinGoneNuts's Avatar
KevinGoneNuts KevinGoneNuts is offline
AKA: Kevin
FRC #0675 (Tech High Robotics)
KevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud of
Don't forget about bumpers... they have to be at least 2 inches from the floor. this makes your plans a bit difficult...
Unread 18-01-2012, 22:35
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Rookie Year: 2007
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
I don't see how this has a problem with the bumpers, the bottom of the bumpers may be mounted from 2"-5" from the floor.
Unread 18-01-2012, 23:09
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
I'll mirror the above comments: load the robot with some weight, on carpet, and then try.
We did this today and it couldn't make it over with the 8'' 2011 wheels (with extra c-channel to provide a 1 inch lift).
Unread 19-01-2012, 10:36
kamikazejoshua kamikazejoshua is offline
FRC #3793
kamikazejoshua is an unknown quantity at this point
What is the height of the bottom of your frame above the floor?
Unread 19-01-2012, 10:50
gman892's Avatar
#2785
FRC #2785
Rookie Year: 2011
The Center of the frame is 7" above the ground.
Unread 18-01-2012, 22:33
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Coach
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Why 80/20? Our team has used the kit aluminum for the last 6 years and never had a problem with it. It's loaded with holes for mounting, and lighter than the extruded 80/20. The only time it bent was in 2005 when we didn't use bumpers (ahhh the good ole days).
Omni's are a good way to go for front wheels and easy turning in 4wd. Otherwise, the kit frame is really easy to adapt a 6 wheel drive. Just make sure your center wheel is 1/8" drop.
Cold Fusion's 10th Season
Unread 18-01-2012, 22:20
Dr Theta's Avatar
Lead Mentor
AKA: Derek Messer
Rookie Year: 2007
Load this up to around 135 lbs and then test if it will turn on carpet. That is always a good thing to check.
  #15   Spotlight this post!
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Rookie Year: 2011
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
For information about CIM use, see this thread, which discusses the pros and cons of sacrificing CIMS for the shooter.
Regarding the barrier, this thread discusses all kinds of barrier strategy.
Also, welcome to CD.
