Go to Post At a much more pragmatic level, organization is what seperates a team full people with really cool unrealized dreams and a team that is trying to figure out it's alliance picks. - phrontist [more]
Unread 19-01-2012, 12:16
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
Team Role: Coach
Rookie Year: 2007
frank.pendzich is an unknown quantity at this point
Key-Way for Gates Sprockets
The Gates sprockets we have are smooth bore. We'd like to cut a key-way in them, but don't know how to do it. Is there a special tool to do this? Where can I get it?
Unread 19-01-2012, 12:20
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Re: Key-Way for Gates Sprockets
Yes, you will need a broaching tool, the right broach key, and an arbor press.
Look at the "single keyway broach" on this page: http://www.engineersedge.com/manufac...hing_types.htm
I would assume a tool and die shop/supply store would stock a set.
Unread 19-01-2012, 13:10
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
We use this one http://www.grizzly.com/products/Keyw...9-pc-HSS/G9771 to great success, but you have to be careful not to break the broaches with an offset press. Bending = bad!
The good news is that overall they're quite easy to use. This set goes up to 1/2" diameter holes, which is as big as we've ever needed. We were given a set for even larger holes and have never used it!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 20-01-2012, 08:20
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
You can also try drilling into the "hub" part of the sprocket and using a set screw. Once the sprocket is in place on the shaft, drill into the shaft, about 1-2 mm, through the hole for the setscrew to give the setscrew somewhere to "bite". It is also possible to use two setscrews for added security. Make sure the sprocket is clamped securely when drilling. This is probably best done on a drill press.
Unread 20-01-2012, 08:26
pfreivald's Avatar
In my experience, there is no reason to use a set screw when you can use a spring pin. We replace all of our set screws with spring pins after a wonky set screw almost cost us an FLR 2010 blue banner!
Otherwise, yes, you can use a drill press to drill straight through the two items you want to couple and then press in a spring pin... I caution, though, that while spring pins are strong they are not invincible, and a keyed shaft is much stronger.
Team 1551
I write books, too!
Unread 20-01-2012, 08:28
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
We've used this method before on sprockets with varying degrees of success. It's not the 'right' way to do the job, but it will work - assuming you can keep the set screws tight at all times and that they don't slip. We've dimpled the shaft (Drill a small blind hole into the shaft for the set screw to fit into as stated above) and also done 'D' and 'Double D' shafts where a flat side or two is added to the round shaft for the set screw to ride on. Again, it's not the right way to transmit torque but if you're in a jam it will 'work'.
Broaching as stated above would be the ideal method, but requires semi-specialized tooling and a bit of skill/patience. Depending on your location, you may be able to find a local machine shop that's willing to broach the sprockets for you for little to no cost, from the few times I've seen it done, it doesn't take long at all.
You could also buy a hex broach (my preferred method of power transmission) and run hex shafts etc. Running hex does present it's own set of issues though, you'll need to find hex bearings, hex stock, etc, etc - and I'm not sure what the availability of those items looks like over your way.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 20-01-2012, 08:57
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Hex is nice, and some of those issues can be worked around. Hex stock from Mcmaster is cheap enough that I dont cringe about buying from them in a pinch. And for hex bearings, we've often used the "poor mans" hex bearing instead of buying specific hex ones for 3/8" hex shafts. We take a standard 1/2" FR8ZZ roller bearing and a bronze bushing. Broach the bronze bushing with a hex, and insert the bushing into the bearing.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 20-01-2012, 09:00
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
Friendly Reminder: In many cases when using hex shafts, it is possible to use a lathe to turn down the two ends of the shaft to a round to use standard bearings.
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Unread 20-01-2012, 09:36
arizonafoxx's Avatar
arizonafoxx arizonafoxx is offline
FRC #4395 (T-Rex)
arizonafoxx is an unknown quantity at this point
To the teams that have an arbor press what rating do you recommend. Can a 1/2 ton arbor press get you by or do you need a 1 ton or better? Is there certain brands to stay away from?
Unread 20-01-2012, 10:08
pfreivald's Avatar
The first year we broached keyways, we tapped them through with a rubber mallet. It worked great as far as creating the keyway, though it's hard on the broach and is not something I would recommend. (We were both time-desperate and had no idea what we were doing.)
So that said, I think a small press would be fine. The 12-ton bottle jack press we now have is massive overkill.
Team 1551
I write books, too!
Unread 20-01-2012, 10:14
FRC #4395 (T-Rex)
It seems like most places have a 1/2 ton for around $50 and a 1 ton for around $100 I am wondering if the extra $50 in necessary when mostly we would want to make 1/8" keyways. Or am i not even in the ball park when it comes to the press? I figure maybe to extra $50 is better spent on a good quality broach.
Unread 20-01-2012, 10:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yesterday we took apart something on our 2009 robot, a steel sprocket that sat on a keyed shaft. The keyway in the sprocket looked funny...and slowly I remembered why...we made it using the saber saw! Just clamp the pulley in a vise, and saw the slot in it.
Scary, but it worked well enough on that one to win the AZ regional and it survived Championships.
Unread 21-01-2012, 09:30
mentorDon's Avatar
mentorDon mentorDon is offline
FRC #1764
mentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these parts
If you are going to use an arbor press make sure the press is large enough so that the broach/sprocket length distance will fit into the press. A 3 ton Grizzly arbor press has a working height of 11 1/8 inches. While a 1 ton only has a working height of 5 inches. It really doesn't take a lot of force to broach a small keyway slot but the equipment must be able to open up enough for your work piece to fit.
Unread 21-01-2012, 09:39
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
While not the correct way, we have been using the drill press to broach 1/8 and 3/16 key ways. This year we have a press. Note hardened sprockets and gears are nearly impossible to broach. Annealing the hub with a torch thru the bore worked last year.
