Go to Post ...or it might be good to avoid doing stupid things like smashing a thin metal casing with a steel hammer... - Cory [more]
Unread 19-01-2012, 18:38
Citrus Citrus is offline
FRC #1678
Citrus is an unknown quantity at this point
Calculating distance with an Axis Camera 206
My team is using an axis camera to calculate the distance to a target. The distances we are currently calculating are up to a foot off, depending on the location, lighting etc. The calculated distances are worse at angles. What accuracy range are other teams getting? Do you think the camera is the best way to get the distance? We have also done tests with the ultrasonic sensor which is sometimes very accurate and other times gives strange results.
Thank you.
Unread 19-01-2012, 19:57
Re: Calculating distance with an Axis Camera 206
How are you calculating the distance using the camera?
Greg McKaskle
Unread 19-01-2012, 23:12
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
I second this question. If you can't get better estimates from the axis camera, you might try using the camera as a sanity check for an ultrasonic sensor.
Unread 20-01-2012, 07:01
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
With any vision system, you could fill in the area of the "square" target that is found with the "edge detection". This way you get a solid square.
Once you have a soild square, now run an "area detection" of the square.
This will get you a size. The bigger the area, the closer you are. The smaller the area, the further away you are.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 20-01-2012, 10:43
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
A smaller area could also mean you are just farther away from the line perpendicular to the target, even if you are the same distance from the target itself.
Citrus, what algorithm are you using to compute distance?
Unread 20-01-2012, 13:10
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
Team Role: Coach
Rookie Year: 2011
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Would it be more accurate to use the ratio of size of the rectangle in comparison to the overall picture (ie. The smaller the rectangle in pixels, the farther away you are moving from it) and then using the length and width of the sides to calculate for angle?
And I'm one of those NEMs (Non-engineering Mentors) so the math escapes me completely here.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 20-01-2012, 14:08
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
Team Role: Leadership
Rookie Year: 2010
cjlane1138 is an unknown quantity at this point
Can someone please post the documentation for detecting the squares and tracking them? I can't seem to find the PDF's or tutorials.
Thanks,
Eagle Engineering 1138
Unread 20-01-2012, 14:48
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
Rookie Year: 2012
shuhao is an unknown quantity at this point
There are numerous algorithms... we are trying opencv with relatively little success.
Anyone else have better experiences with opencv?
Unread 20-01-2012, 15:12
commonsense commonsense is offline
FRC #3452
commonsense will become famous soon enoughcommonsense will become famous soon enough
With the range finder we received you shouldn't need to use the Axis camera. The real question is has anyone found information for coding the rangefinder?
Unread 20-01-2012, 15:17
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
It's analog. It outputs a voltage read as an analog channel.
Relating to OpenCV, this shouldn't be necessary on the cRio as NI Vision (CVI) is fairly optimized (and already compiled) for VxWorks.
Kettering Motorsports
Unread 20-01-2012, 17:16
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
Rookie Year: 2007
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Basically, yes. Involves a fair amount of trig, but this is how I am doing it, and it works well.
Unread 21-01-2012, 02:17
FRC #1678
We are using the height of the target and comparing it to the height of the camera image.
Unread 21-01-2012, 09:22
Rookie Year: 2012
About opencv...
I personally would like to mount a netbook on the robot
Unread 21-01-2012, 10:42
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Team Role: Coach
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
If you haven't already, you should read this white paper on vision and the axis camera. It is from National Instruments and is specific to this years competition. The url is https://decibel.ni.com/content/docs/DOC-20173
You may need to register to download. It provides good detail on the algorithm used and possible errors.
Jeff Beltramo
Team #1922
Concord, New Hampshire
  #15   Spotlight this post!
Unread 21-01-2012, 16:48
Solauj's Avatar
Solauj Solauj is offline
FRC #0461 (Westside Boiler Invasion)
Rookie Year: 2010
Solauj is on a distinguished road
We are using OpenCV to track the vision target this year. I have been fiddling around with color tracking over the summer, so I have a little experience with it. I have been able to track the tape up to 16ft. away. Due to a lack of smoked polycarbonate, I don't have the actual vision target built yet.
Does anyone known how dense the polycarbonate is? All the manual says is "1/2 in. smoked polycarbonate" with no more description.
As far as determining distance, I thought using the target's relative size to the image size would be viable because the target is 2ft. wide.
What problems are you having with OpenCV? I'll try to help. Also you should get a hold of the book Learning OpenCV: Computer Vision with the OpenCV Library (ISBN: 978-0-596-51613-0). It's great for reference and (obviously) learning the basics.
