Go to Post I can't help looking at the new center piece my wife put on the dinning room table and think to myself, "non-functional decoration" - DarrinMunter [more]
Unread 20-01-2012, 01:30
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Multiple camera targets..?
I haven't had a chance to play with code yet - so I may be missing something horribly obvious.
If there are 4 squares that the camera code can detect, how do we choose which one we want to aim at? does the default code/tutorial have something that supports 4 targets? Does it only recognize one at a time?
This concept just confuses me. We should have our driver station running soon so we can try it (labview)
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 20-01-2012, 07:11
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Multiple camera targets..?
I believe that it will list them top-bottom left-right. So if you want the top target then it will be the first one. But don't quote me on this, we haven't tested it yet.
Unread 20-01-2012, 07:28
The VI will list the targets that it found. You do not have to use them all. You should probably evaluate your robot's capabilities and decide which are most useful.
A simple version is to look for only the low target using the Y position. You could also choose the one that is closest to where your turret or mechanism is pointing, which may be the one with the smallest absolute X value. Another simple choice is to use the first in the array and pretend the VI didn't even send the others. Your choice.
Greg McKaskle
Unread 26-01-2012, 11:35
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
I'm not sure if this has been covered or not, if it has, please point me to it.
In the Vision Processing.vi, the "mjpg loop.vi" is used to aquire and notify the modules that an image is ready. But the context help says that with the 1011 camera, mjpg is more efficient. Does that also indicate that with the 206 jpg in better to use? Would replacing the mjpg loop.vi with the jpg loop.vi be appropriate for working with the 206 camera.
See the attached image as reference.
Name:	MJPG or JPG Loop .JPG
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 26-01-2012, 12:37
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
My understanding is that mjpg is good for both cameras, but jpg is only good for the 206.
Unread 26-01-2012, 20:28
Correct. The 206 had roughly equivalent frame rate using JPG and MJPG. The M1011 has a JPG frame rate of about 8 and the MJPG was equivalent to the 206.
Greg McKaskle
