Go to Post Do it the good ol' American way and throw money at the problem. In other words, get out of there and call a professional to take care of it. - sanddrag [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 22-01-2012, 14:54
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: CANJaguar
Originally Posted by Bryscus View Post
From the getting started guide:
Total Cable Length
(maximum)
20 ft / 6.1m Tip: Start with this length of bulk cable and cut all
segments from it to ensure compliance.
Termination Resistance 100 At each end of the network.
Just quoting specs.
- Bryce
The 'Getting Started Guide' is not the CAN spec, IS0 11898:1993(E) is.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 22-01-2012, 17:37
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
Rookie Year: 2007
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: CANJaguar
Originally Posted by Mike Copioli View Post
David,
I have to disagree with you on this. According to CAN spec IS0 11898:1993(E) Table 15, the maximum cable distance for 1Mbit/second is 40 Meters not 20 feet.
We have also tested at distances much greater than 20 feet without issue using 120 Ohm's of termination on each end of the BUS.
FYI a termination resistor of 100 ohms is outside of the spec. Teams using 120 ohms resistors should have no issues related to signal reflection.
Yes, that is what the CAN spec says. However, I am talking about what we specify for Jaguar.
They differ in the following ways:
  • CAN Spec states 40 meter cable lengths using twisted pair cable
    • Jaguar uses non-twisted modular cable
  • CAN Spec states 120 ohm terminators
    • TI specifies 100 ohm terminators for the following reasons:
The concern is with bit timing, not signal reflections.
Ideally each Jaguar would be configured with its own specific bit-timing parameters (parameters that define when the CAN module samples the bit). These parameters depend on a lot of factors including location on the bus, bus impedance, the number of drivers on the bus, etc.
In this specific application (FRC) a lot of those factors are unknown. What works for one setup may not work as well for another. During our testing of Jaguar we found that as the number of Jaguars increased and the cable lengths got longer, some Jaguars would not sample the bits correctly. We saw that the bus was taking longer to transition from the dominant to recessive states fast enough when every CAN driver on the bus was driving dominant.
We were able to successfully improve the timing by lowering the resistance of the terminator to 100 ohms. The lower resistance helped pull the CANH and CANL to the recessive state much faster. We also found that minimizing the cable lengths between the Jaguars helped a bit too.
The bottom line:
TI specifies 100 ohm termination resistors and ~20' total of cabling. This differs from the official ISO specification for CAN, but should ensure that teams have the best experience with the Jaguar when using CAN.
-David
Unread 22-01-2012, 21:38
Re: CANJaguar
The bottom line:
-David
Dave,
Our findings tell a different story. I would be happy to share them with you.
Mike Copioli
Unread 22-01-2012, 17:02
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Rookie Year: 1999
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Mike,
This wouldn't be the first time a device isn't fully compliant with a spec. One thing I've learned in the industry is that if you design a system to the spec of a bus and not that of a part you'll get burned every time - SPI, I2C, EBI, you name it. The reason microprocessors have so many options for these buses is that parts are so varied.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
