Go to Post Let this be a hint to the hardware teams. Deliver that robot early and give the software and driving team time with the robot. IR3 has proven it can be done. - Doug Leppard [more]
Unread 20-01-2012, 21:57
Andrew Lawrence
Posts: n/a
Re: Mechanum Wheels?
Originally Posted by O'Sancheski View Post
I disagree with this statement. WPI has a complete library for mecanum wheels. My old team used them last year for the first time and had them programmed on the drivetrain the day we received the shipment from AndyMark.
I mean when you go into the real nitty gritty coding stuff. THe code they give you is fine, but to make it better takes some work.
This is just what I've been told by our programmers, I'm not a master of code myself, however my trustful programmers are.
Unread 20-01-2012, 22:03
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Could you please ask your programmers to tell us how they made it better than the WPI code.
Unread 20-01-2012, 22:06
Andrew Lawrence
Posts: n/a
The themselves haven't programmed it, but from reading the WPI code and looking at how to make it better, they said getting it perfect (not 100%, but a close 99%) would take some extra code.
I'll ask them at our next meeting, though. Now I'm interested, too.
Unread 21-01-2012, 00:08
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Code:
void RobotDrive::MecanumDrive_Polar(float magnitude, float direction, float rotation)
	// Normalized for full power along the Cartesian axes.
	magnitude = Limit(magnitude) * sqrt(2.0);
	// The rollers are at 45 degree angles.
	double dirInRad = (direction + 45.0) * 3.14159 / 180.0;
	double cosD = cos(dirInRad);
	double sinD = sin(dirInRad);
	double wheelSpeeds[kMaxNumberOfMotors];
	wheelSpeeds[kFrontLeftMotor] = sinD * magnitude + rotation;
	wheelSpeeds[kFrontRightMotor] = cosD * magnitude - rotation;
	wheelSpeeds[kRearLeftMotor] = cosD * magnitude + rotation;
	wheelSpeeds[kRearRightMotor] = sinD * magnitude - rotation;
	Normalize(wheelSpeeds);
	m_frontLeftMotor->Set(wheelSpeeds[kFrontLeftMotor] * m_invertedMotors[kFrontLeftMotor]);
	m_frontRightMotor->Set(wheelSpeeds[kFrontRightMotor] * m_invertedMotors[kFrontRightMotor]);
	m_rearLeftMotor->Set(wheelSpeeds[kRearLeftMotor] * m_invertedMotors[kRearLeftMotor]);
	m_rearRightMotor->Set(wheelSpeeds[kRearRightMotor] * m_invertedMotors[kRearRightMotor]);
This is straight from the RobotDrive source. What could possibly be improved?
Attending: MN Duluth Regional
Unread 20-01-2012, 22:01
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
I'm not saying no mecanums (or however you spell it), but these are some points made in previous threads:
-Less traction on the key
-As already said, loss in pushing power
-Heavy
-Forces you to use maximum number of motors for drivetrain (not usually an issue)
-While they may not affect your ability to go on the bridge, the ability to stay without being pushed off or falling off of the bridge tips your direction will be tough to deal with
-You won't be driving circles around other's bots unless you have a lot of practice.
-In order to work to their fullest extent, require a lot of thorough engineering
-More complicated to code, even at the minimum level
Like I said, I'm not telling you not to use them, but when you do, be careful and engineer it through (Not meant to sound like most interesting man in the world meme, though I'm tempted. )
  • We've been using Mecanums for the past three years and have found no huge loss of traction
  • Usually, but this depends on the drivetrain.
  • Definitely; Mecanums are a lot heavier than conventional wheels.
  • I think most teams use 4 CIMs to drive anyway because it gives the robot a ton of power.
  • Mecanums powered by Toughboxes don't get pushed around as much as people think, but it's defeinitely soemthing to consider.
  • Agreed, a lot of practice is needed with Mecanums to be extremely good at them.
  • Not a lot of engineering, it's really only the initial one-time assembly that matters in the long run.
  • Actually, my team uses all of 20 characters for our Mecanum code, not counting the button to turn it on
Just my experiences with Mecanums.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 20-01-2012, 22:05
Andrew Lawrence
Posts: n/a
Originally Posted by Djur View Post
  • We've been using Mecanums for the psat three years and have found no huge loss of traction
Thanks for posting this! I like the other opinions.
Unread 21-01-2012, 14:40
Mara's Avatar
Mara Mara is offline
Team 696 Safety Czar
FRC #0696 (Circuit Breakers)
Team Role: Mechanical
Rookie Year: 2010
Mara has a little shameless behaviour in the past
They're expensive and our team doesn't have any experience with them. We always end up sticking with good ol' tank drive.
Unread 20-01-2012, 23:41
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
-Heavy
-While they may not affect your ability to go on the bridge, the ability to stay without being pushed off or falling off of the bridge tips your direction will beN tough to deal with
I always laugh when people make posts like these. We played defense in 2010 with mecanums and definetly didn't get pushed around.
And your not going to do well with any robot without practice.
cole?
Unread 21-01-2012, 10:09
JaredSanMiguel JaredSanMiguel is offline
FRC #0930 (Mukwonago B.E.A.R.s)
JaredSanMiguel is an unknown quantity at this point
I don't think this is the case at all. I was my teams driver two years ago when we had mecanums in break away. After a couple days of driving the maneuverability of our robot was evident.
Not to discredit what you are saying, if you don't have a couple days to spend on driving then learning at competition may be difficult.
Just don't want to discourage teams, the driving can be mastered in a relatively short amount of time.
Unread 21-01-2012, 10:15
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
As of last year I still think a robot with Mechanum has never made it to Einstein.
Unread 21-01-2012, 10:27
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Straw man.
That's like saying women are poor drivers because no woman has ever won the NASCAR championship.
As of last year, no robot with a Kinect has ever made it to Einstein either.
Hi!
Unread 21-01-2012, 10:29
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
This is correct.
Though, 2826 made it a stone's throw from Einstein in 2011 with their 'Octocanum' drive. Had 71 not had issues in the Curie finals, mecanums may have made it. We're still quite some time off from seeing a pure mecanum make it to Einstein though.
Originally Posted by Taylor View Post
Straw man.
Is this really a valid comparison?
Look at the number of women in Nascar vs the Number of teams who use Mecanum wheels in FRC.
And the Kinect point is completely irrelevant here, Mecanum wheels have been in FRC since 2005, at my count that's 7 seasons that they could've and or should've made it to Einstein if they were superior (Though, Mecanum usage really exploded in 2007 and they were illegal in 2009) - the Kinect is new this season, maybe you can make the Kinect comment again in a few years.
The reason a Mecanum robot hasn't made it to Einstein is a really deep topic. I believe, and may be wrong here, but 51 is the only team in the Modern Era to make it to Einstein with any sort of non-swerve omni drive. Maybe Omni Drives that rely on Omni Wheels and Mecanum Wheels just aren't a good fit for FRC, who knows?
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 21-01-2012, 10:33
Chris is me's Avatar
AKA: Pinecone
I'm just going to chime in and add that while mecanums aren't ALWAYS bad... 2012 really isn't the year for them.
Unread 21-01-2012, 14:05
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
for whom? If you are a rookie or just inexperienced team, and you want to be able to shoot, mecanum is pretty simple to implement (if you buy AM wheels anyway) and takes care of your drive and gives you an easy way to line up your shot and your approach to the bridge.
  #15   Spotlight this post!
Unread 21-01-2012, 21:25
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
Rookie Year: 2010
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
-Heavy
Most of these are fairly situational arguments. We're going with mecanum this year and I'm fairly happy with the decision, though I suppose that requires some justification. A little history is in order. This is gonna be long...
We, like many other Hawaii teams, started in Overdrive. We built an 8-wheel tank drive and did fairly well, though our claw was too easily damaged and we didn't make it very far in the competition. We observed that some of the drives that were highly successful in Overdrive were omnidirectional drives that could abuse the "lap" rule and kept it in mind for later use.
Lunacy was Lunacy, of course. We didn't get a chance to try omnidirectional movement, though we actually ended up being a really solid defensive robot because of our uncommon three-wheel single-swerve drive. We misanalyzed the game and didn't build a floor collection device, so we didn't make it out of Hawaii. Our driver loved being more mobile and better at turning than all of the other robots at the competition.
In Breakaway we again misanalyzed the game and thought that crossing the bumps was going to be an important part of gameplay, which it really wasn't. But we didn't want to be able to be blocked coming off of the bump, so we figured we needed horizontal movement on top of the bump or right behind it. So we picked mecanum. We did fairly well that year, captaining a semifinalist alliance, but were knocked out by the eventual champions. However, or "ball magnet" was very substandard and we couldn't strafe while using it, so we ended up not using the strafing at all. It was pretty bad, honestly; we had no room to use mecanum's maneuvering and we couldn't even really strafe. However, our driver got some practice maneuvering outside of the competition and we got software for mecanum developed.
In Logomotion we analyzed the game perfectly well, but the design we set out to build was beyond our capabilities to achieve. We decided on mecanum because we had had experience with it the previous year, we thought that strafing in the zones would be useful, and we liked the added maneuverability. The drive was actually great, but our arm was finished too late and we were unable to use it at competition, rendering us a defensive/feeder robot. We used the newly-lightning-fast mecanum drive to great effect in feeding, but because we were a feeder and not a scorer, we once again failed to make it to Worlds. However, we improved our mecanum software, got used to how strategy plays with mecanum, and saw how useful it can be on a big field.
This year, we saw the field and immediately thought "mecanum". The wide-open spaces, no-pushing zones, and small game objects just scream for a robot that uses maneuverability rather than power to avoid opponents. We'd gotten used to the idea of the mecanum drive, we had a very good one from the previous year sitting in our shop to model off of, and our analysis showed that bump-crossing (sort of like in Breakaway) is nice but not necessary. Our driver, who had gotten very good with mecanum, has sadly graduated, but our new trainees have taken to it quickly. We're pretty happy with our decision.
So with regards to your points...
1) Precise motion on the key is fairly irrelevant if you turret your ball-scoring device.
2) The loss in pushing power actually isn't as severe as people make it out to be. We've never been pushed around by a tank drive and we've even pushed a few (sideways) ourselves.
3) It's possible to get an effective robot very light this year by consolidating mechanisms. We are estimating that we'll come in way light even with mecanums. We need the extra weight.
4) Not an issue because there are so many motors this year.
5) Refuted by our testing of the bridge balancing two mecanum robots. Sorry, we don't have video.
7) Already done in previous years.
8) Already done in previous years. (Breakaway was sort of a happy mistake...)
You may have noticed that I skipped 6. I did it because I wanted to add even more text to an already unnecessarily overlong post.
Too many people think of mecanum in ways that are fundamentally wrongheaded. Mecanum isn't going to "run circles around" a competent defensive robot. Honestly, if you're running circles around anyone, regardless of your drive, their drive is probably atrocious. Neither is pure horizontal strafing very useful. The actual value of mecanum is in the more complex maneuvers that few first-time-with-mecanum teams discover (we certainly didn't discover them in '10). The bootleg turn, circle strafing, and impact redirection are three examples of genuinely valuable things that mecanum enables you to do much more easily than tank drive does, but you hardly ever hear about them in mecanum discussion. Pro-mecanum people and anti-mecanum people alike often don't know what they're talking about.
Other assorted thoughts on mecanum drives, because apparently I don't feel like I've typed enough yet...
The pushing-power thing is blown way out of proportion. Unless your drive is stupidly weak or your opponent's is stupidly strong, you're not going to get shoved around, and mecanums can push tanks sideways (and occasionally head-to-head).
Mecanum can maneuver well on the bridge and the key alike, based on our tests. Super-precise maneuvers on the key don't seem all that useful anyways.
The fragility thing is blown way out of proportion, too. As long as you don't do anything stupid (like drive over the bump this year without wheel guards), you'll be fine.
Not everyone can drive a mecanum well. Some people who pick them up drive them like tank drives that can strafe horizontally, which is dumb, because that just makes them weaker tank drives with a bonus feature that your driver is likely to forget about. It does take practice, and it also takes a different way of thinking.
The no-mecanums-on-Einstein thing is a silly myth. FRC is fairly stratified and teams feel comfortable doing what they've done before; teams who have been around for a while (which tend to be the best teams) have been doing tank for a long time. Many teams who have the resources to get to Einstein have the resources to build a swerve instead of a mecanum. Which is better.
Even though we've used mecanums each of the last three years, I'd like to think we're not set in our ways. This year, we essentially knew going in that we wanted to use mecanum because it was the only thing that we've really refined. However, this was a good year to be forced to use mecanum. I've always had some doubts--a lot of very smart mentors from very good teams swear off mecanum, and I figure they can't all be wrong and we can't be the only ones who are right. We're planning to branch out next summer when we have the resources and the time to develop a good new drive.
In conclusion, mecanums are good when:
-there are wide-open spaces on the field
-game objects are fairly small
-your programmers have a modicum of experience
-the game is not pushing-heavy
Mecanums are bad when:
-your driver is entrenched into "tank-thinking"
-your programmers are very inexperienced
-the field contains many obstacles or small spaces
-you need to push to get access to a zone
-you have the resources to build a swerve
I hope that this post didn't bore anyone to tears and that it was informative, if only to help you see the (maybe misguided from your point of view) thought process of someone who's coached a mecanum robot for all of his time in FRC.
