Go to Post DonRotolo used COMMON SENSE. ... ... FIRST/Chief Delphi Community fainted! - PayneTrain [more]
Unread 01-20-2012, 09:18 PM
kevint kevint is offline
Kevin Tesei
AKA: Kevin Tesei
FRC #1323 (Mad Town Robotics)
kevint will become famous soon enough
image processing with javacv and smart dashboard
Hey this year our teams has decided to do the image processing on the driver station laptop (java). I have the smart dashboard installed and can use it to send values between the robot and the driverstation. I was wondering how to get the video feed from the axis camera to appear on the smart dashboard. Also I haven't been able to get the libraries for javacv to appear in my netbeans. I've read through the wpi cookbook and a few other places but have hit a dead end. Any help would be appreciated.
Unread 01-21-2012, 03:12 PM
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Re: image processing with javacv and smart dashboard
when you say how, do you mean what do you plug in on the robot to get video feed? if so, then plug in an ethernet cable into the camera and into the CRio.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 01-21-2012, 03:30 PM
Kevin Tesei
AKA: Kevin Tesei
No I know how to do that. I can get the camera feed on the old dashboard. I need to know what settings I need to use or something...
Unread 01-21-2012, 05:54 PM
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
By default, the Axis camera will not show images to the Smart Dashboard.
You must change the settings on the camera to allow anonymous viewing. After that, if the IP of the camera is set (make sure View > Editable is checked then right click the camera and select Preferences) you should start seeing images.
The wiki page of the SmartDashboard has some useful information, including how to make your own extensions.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 01-23-2012, 07:47 PM
Kevin Tesei
AKA: Kevin Tesei
Thanks the anonomous request thing was the problem. That's perfect. On a similar note I found out were to get the jar file I needed. They were on the left >_< http://code.google.com/p/javacv/
Unread 04-04-2012, 06:58 PM
How do you change the settings for anonymous viewing
Unread 04-04-2012, 08:17 PM
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Use a web browser to browse to he camera's IP address
Login is username: FRC Password: FRC
Go to Setup and there will be a check box for autonomous viewing
Unread 04-07-2012, 04:35 PM
Just Itinerant
The check box is found under
Setup->System Options->Security->Users
Enable anonymous viewer login
Here's a screen shot of the page on the Axis M1011. It's similar on the older Axis 206 camera.
