Go to Post Just be nice. It works better in the long run. - Libby K [more]
Unread 21-01-2012, 13:46
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
tilky is an unknown quantity at this point
24 volt solenoid
how would you open and set a 24, as opposed to a 12 volt solenoid
Unread 21-01-2012, 14:06
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Re: 24 volt solenoid
Exactly the same way; the only different part is the voltage wired to the solenoid module. All else is the same.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 21-01-2012, 14:08
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
I meant in the code sorry
Unread 21-01-2012, 15:29
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
As Phil said, in programming, there is no difference between a 12 volt solenoid and a 24 volt solenoid.
Unread 21-01-2012, 15:32
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
a regular open goes to the sidecar, how do you make the solenoid open in the output from the 24 volt module. Sorry, i dont know how to say what i need.
Unread 21-01-2012, 16:55
plnyyanks's Avatar
AKA: Phil Lopreiato
Rookie Year: 2010
Again there's no difference, but I'll try and be a little more thorough in my answer.
Both 12V and 24V solenoids will run off on an NI-9472 module (or more commonly known as a solenoid module). You will plug your solenoid (regardless of its voltage) into the module with the breakout installed. You will code both types of solenoids the exact same way - open them, and control weather or not each port on the breakout is an open or closed circuit.
Now, here's the only difference: the solenoid breakout requires a power input (it's on the top left of the picture on the linked page). It can handle both 12V and 24V (but not at the same time). You will either wire 12V or 24V from your PDB to that breakout. Note that you can not use both 12V and 24V solenoids simultaneously on the same cRIO module.
So, really, there is not any difference between the two voltages of solenoids, except the power your wire to them.
Unread 21-01-2012, 17:47
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Using the cRIO solenoid modules there typically won't be a difference in code.
There are some slight code differences in setting up a double solenoid vs. a single solenoid (the voltage still doesn't matter though).
I don't want to confuse the issue too much, but I wanted to mention that there is a variation for 12v solenoids (not possible with 24v versions) that allows you to power them through Spike relays. That would be coded differently, since it doesn't use the cRIO solenoid module at all.
Unread 21-01-2012, 18:04
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
thank you so much. I got the impression that 12 volt went to the sidecar.
