Go to Post Also you NEVER need to apologize for asking questions. Asking questions is how you learn. - akoscielski3 [more]
Unread 21-01-2012, 16:08
TomThompson TomThompson is offline
FRC #0847
TomThompson is an unknown quantity at this point
Command based programming problem
We are trying to use the new command-based system in C++. We are getting an error on build that we think might be related to the Command.h file. It is not in the commands directory but there is no way of knowing whether WIPLib actually includes this. None of the classes that eventually inherit Command are recognized.
Tom
Unread 25-01-2012, 00:49
grantf's Avatar
grantf grantf is offline
Software Engineering Mentor
FRC #4061 (SciBorgs)
grantf has a spectacular aura aboutgrantf has a spectacular aura about
Re: Command based programming problem
Tom
Hi Tom,
This is a simple include path problem. Open WindRiver and right-click on your project, then choose "Properties". Across the top of the next window, you will see a bunch of tabs, one of which is called "Paths", click on it. In the middle of that window, you should see 3 entries in a table that all look like -I$(WIND_BASE)/target/h/... Click the "Add" button on the right, and in the new row, put -I$(WIND_BASE)/target/h/WPILib/Commands. This will add an automatic include path to your build system so files will be able to see "Command.h" and "Subsystem.h" etc.
Alternatively, you could #include those files explicitly by doing this in your source files:
#include "Commands/Command.h"
#include "Commands/Subsystem.h"
Hope that helps
Grant
Unread 25-01-2012, 01:24
FRC #0847
I appreciate the response, Grant. Although I haven't tried your first suggestion, the include statements were present in the code and we still had the problem. Have you used the new command based sample template in C++? The line of code that is giving us an error was actually generated by the wizard.
Tom Thompson
Unread 25-01-2012, 01:34
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
FYI -- I just gave a try at compiling the template/example CommandBasedRobotTemplate and it compiled fine for me.
bob
