Bridge mode?
There is several discussions on communication with the crio due to offloadinf tthe vision processing.
Would that work (wifi and/or Ethernet) with bridge mode as bridge mode is used in competition |
Re: Bridge mode?
The ports that will be open on the field WiFi network are in yesterday's team update
What about onboard? Anything about Ethernet?
Re: Bridge mode?
If both devices are on-board there is a rule that tells you a narrow range of ports to avoid
