cRIO serial-CAN no signal
Good evening members of CD,
This year our team decided we would go down the CAN route, enticed by the features offered by it. Originally turned down by the 200 dollar 2CAN, we discovered we could do CAN cheaper with the serial port on the cRio. I have been heading up the change over to CAN. I have updated the firmware of all the Jaguars we are using (3 black ones and 1 tan) to version 101 with BDC-COMM via the usb to DB-9 serial to rj11 adapter that we got in the KOP this year. I can manually control each one though the CAN bus into my computer (all the lights are solid yellow when i open BDC-COMM, and i can set the voltages/current etc). The problem is, plugging the serial to rj-11 adpater into the cRIO's serial port, the jaguars still indicate no signal. I have formatted our 8-slot cRIO for Java with the newest 2012 (v43) firmware including the serial CAN plugin. Any help would appreciated on this. This is also my first post, so tell me if there is anything i should know next time i post. Thanks |
Re: cRIO serial-CAN no signal
Did you turn off the console out dip switch?
Yes I did, if i recall correctly, the 2012 cRIO imaging tool made me set the DIP switch to off before it would allow me to add the serial to CAN plug-in.
Other than that, they are called exactly the same way (when in open-loop mode) as the Victor and Jaguar objects. And obviously you need to use a Black Jag as the first device. When you enable the lights should be steady. - Bryce |
Thank you for the quick reply. Yes, there is a black jaguar being used as the CAN initializer. I have each jag set to a specific ID, and thanks to my mentor they have nice labels too. The java code I have creates 4 CANJaguars, then initializes them, along with RobotDrive in a try statement to catch the exceptions. I suppose the question i have is, does the code actually create the communications between cRIO and jaguars? I have an error free deployed code, but the light on the jags continue to blink yellow (no signal).
Does your Allen Bradley signal light blink? They moved the modules this year (not sure if other stuff is working). You also need to make sure the switch on the cRIO is set to off for the console. Check NetConsole for error messages. C++ code CANJaguar m_motor(5); m_motor.Set(0.1); Pretty simple most of the time. Or: CANJaguar *m_motor; m_motor = new CANJaguar(5); m_motor->Set(0.1); I think you have to use the latter to pass to RobotDrive... - Bryce |
I don't actually recall if our signal light blinks, it's half hidden at the top of our bot. I know the modules are correct, I had the robot driving on PWM second day of the season with new firmware and such. I will try with just one jaguar today, and see if I can get any results. I will be with robot today until about 4 pm EST if there any specific questions that you want me to answer.
Thanks. |
Working 'bot suggests it's probably a code issue somewhere. The best thing to do at this point may just be to check the NetConsole for feedback. The CANJaguar class loves to throw errors to the netConsole, so if there's a problem it will tell you. Do others things work when you try this? Maybe use one on PWM and another on CAN and just tie each one to a joystick axis rather than using the RobotDrive class. Or even simpler, just put in hard values.
Thanks for all the feedback guys. I got it working today, it was a matter of not enabling the CANJaguars with CANspeedcontroller.enableControl(). Everything works now and we have a successful open loop mecanum drive system. We also have a closed loop system that works pretty well also (current mode).
Thanks for all the help. |
#10
Good to hear!
