Go to Post An awesome unveiling video is not necessarily an indicator of onfield performance. - ToddF [more]
Unread 21-01-2012, 20:32
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
Rookie Year: 2000
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Arrow Serial port on CRIO-FRC II
We are having trouble opening the RS232 serial port on the new CRIO-FRC II. Using the exact same code, we were able to successfully open the port and use read/writes on the older 8-slot CRIO-FRC version 1. However, with the new 2012 4-slot version we are seeing an error upon initialization:
Using port: ASRL1::INSTR
error code: -1073807246
We have tried the NI serial port VISA module as well as the WPI version, with similar failures. Has anyone else encountered this problem?
Thank you
