Go to Post your time is better spent in the stands, watching what the robots actually do, as opposed to listening to the builders talk about what they're [I]supposed[/I] to do. - sanddrag [more]
Unread 21-01-2012, 23:13
alb4h alb4h is offline
FRC #3862
alb4h is an unknown quantity at this point
problems debugging
In Target Server Options,
do you always point the Kernel image to the
cRIOFRC_vxWorks image
regardless of the .out file you are trying to debug?
Ann
Unread 31-01-2012, 22:36
wadehas wadehas is offline
FRC #1258
wadehas is an unknown quantity at this point
Re: problems debugging
It depends on which version of the cRio that you have... If you have the 8 slot cRio... the answer is yes... if it is the newer 4 slot cRio, you use cRIOFRCII_vxWorks
-Wade
Unread 02-02-2012, 18:42
FRC #3862
thanks for the response - I'm good now.
Ann
