Build, then Run as Startup results in Conflict?
Everytime we build, then run as startup, we notice we always get presented with this screen shot below. But we click "OK" and the code deploys and runs.
Is this NORMAL? Why is it doing this? Anyone know? |
Re: Build, then Run as Startup results in Conflict?
Yes it's normal. It's just a (very scary) way of telling you that you are overwriting already running code.
Should we be cleaning? Or undeploy first? If so, what's the best way to clean the CRIO or initialize it to get it ready for new code? Is that a more recommended way? If so, the 2012 software documentation did not indicate this but makes sense maybe it should be done.
It's not an error, just a warning. If you're trying to put a new program on the cRIO, you want to terminate the currently running program. Just click OK like you have been doing.
We have the same problem, but it won't run at all. We get no robot code.
What are you trying to run, and how are you trying to run it? If you Build the project and then Run as Startup, it should work. If you're just trying to Run a VI using the run arrow on the toolbar, only the Robot Main.vi will properly start the code running to establish communication with the Driver Station.
Summary of what everyone said:
First, you must build the code. then you must deploy the code, and then run at startup. This error will occur when you are deploying the code, just because it is telling you that the robot is on. Just click okay, and then run on startup. When it then asks to reset the cRIO, click no, and manually turn your robot off and on. When you turn it back on, it should have the new code. |
Second, you should click Yes when it asks if you want to reboot the cRIO. That's how it starts running the newly loaded program. Removing power from the robot will make you need to wait for the DAP-1522 to boot and for the Driver Station to reconnect to it. That will take almost twice as long as just rebooting the cRIO from the prompt. |
